Autocross and Road Racing Technique There is more to life than a straight line
Sway bar adapter kit? I'm confused!
Old Jan 28, 2004 | 03:43 AM
billsbird's Avatar
I went to the Jeg's web-site to order a Suspension Techniquies front sway bar and it said "if no OEM rear bar use sway bar adapter kit #876-55310". What are they talking about??? Thanks, Bill...
Old Jan 28, 2004 | 06:44 AM
teke184's Avatar
what kind of car do you have?
when i ordered my BMR sway bars, i needed to reuse some of the mounting hardware. namely the brackets, bolts for the front and on the rear the U-bolt brackets.
so if you didn't have those originally, most kits wouldn't come with it.
Old Jan 28, 2004 | 03:13 PM
billsbird's Avatar
....a '94 Trans Am. I'll call Jeg's in a while and order the sway bar and ask. Thanks for your reply teke 184.... Bill...
Old Jan 29, 2004 | 06:56 AM
teke184's Avatar
as long as they are designed for the car, the bars should bolt right up...
exept you may need bigger bushings to accomodate thicker bars.
Old Jan 29, 2004 | 11:31 PM
billsbird's Avatar
....ah, bigger bushings, thank you
RUENUF
Mar 13, 2016 03:39 PM
HarleyZ28
Oct 5, 2015 06:23 AM
96SilverRam
May 28, 2015 02:09 AM
96SilverRam
May 5, 2015 09:56 PM
8T8IROC
Mar 26, 2015 09:02 PM
