Autocross and Road Racing Technique There is more to life than a straight line
suspension gurus......question inside relating to front end
Old Jun 27, 2002 | 09:05 PM
sleeperZ96BT's Avatar
Post suspension gurus......question inside relating to front end
what parts are inmcluded in the fonrt end of a 1996 Z28? i have a SLP level 1 kit coming in and while im at it i figure i might as well replace all my 75,000 mile stock pieces with Moog pieces. if you could list them or send me a link t hat has them that would be great. pricing to replace it all would be cool too. i want to build a car that corners like a bastard......
thanks,
brian
Old Jun 28, 2002 | 04:33 PM
Dr.Mudge's Avatar
Post
"Corners like a bastard" most of the time, = driver, race tires, and alignment.
Springs/shocks and that sort, will depend on what kind of track and speeds you'll be seeing.
Old Jun 28, 2002 | 10:44 PM
Post
well, im not gonna be auto crossing it a lot, but i would like to be able to once in awhile. here is what i have done:
BMR STB, kenny brown DD SFC's, SLP level 1 suspension package, endery suspension endlinks and bushings. basically what im looking for is the replacement of all the stock front end pieces and was looking for a list of what i could do (ie. ball joints, tie rod ends, etc).
thanks,
brian
Old Jun 29, 2002 | 06:40 AM
thumpha's Avatar
Post
I'm no guru, but if you want to change out your front parts you can get a chromolly k-member, ($500ish), Chromolly adjustable uper and lower A's ($400ish each) and whack about 40-60lb from your front end in the process.Rigidity from sfc and phr/lcas.. Sway bars($420), Big slotted brakes if you don't have em, some light 17 inch rims with great rubber, and koni dual adjustables all around and you'd have absoluteley ruled out all factors other than operator error/poor setup. Should be able to do it maxing out a single credit card or selling the wife's car......
Old Jun 29, 2002 | 08:48 AM
Post
thanks for the post.....i dont wanna max out the CC at this point. what are the parts of the a-arms and kmember? what composes the factory parts that i could replace with someone like Moog's parts, ie tie rods, ball joints etc?
brian
8T8IROC
Mar 26, 2015 09:02 PM
karguy16
Mar 6, 2015 01:33 AM
dbrockma
Feb 16, 2015 02:56 PM
siguy
Nov 27, 2014 10:07 AM
