Rear Suspension Creaking - 96 Convertible Z
Just bought a 96 Vert Z28 - I got a nasty creaking coming from the rear when the suspension
compresses. Since NJ temperature has been running in the teens lately I haven't really had the
drive to crawl under and look. I am hoping that is as simple as sway bar bushings. Anybody else
had this problem?
had this problem?
I've got a 99' convert. and it does the same thing. Actually, everyone I know that has a Camaro has the same symptoms. It's especially noticable when going over speed bumps...You're right though, it's the sway bar bushings. An easy fix. RkSport has a bushing kit that's moderately priced. I've just been dealing with the "grandma's rocking chair" sound. It's nothing that serious, but kinda annoying.
There are 2 things I did at the same time that eliminating squeaking from the rear: (could have been either)
1) grease rear sway bar under the "strap" bushings--or whatever they are called
2) grease the side of the LCA rubber
F'n1996Z28SS
Aug 23, 2023 11:19 PM
squarehead
Nov 21, 2014 08:02 PM
94z28jbw
Sep 8, 2002 03:22 PM
