Autocross and Road Racing Technique There is more to life than a straight line
putting 99 C5 rims on 99 Z28 - need help
Old Dec 28, 2002 | 04:12 PM
MARSTAUT's Avatar
I want an extra set of tires for AutoX so I bought these C5 rims. What types of modification do I have to do to get them to work. I know that the center hole must be filed out alittle, but I am worried about the back spacing in the rear. Do I need to use a spacer? Also so what Is the widest tire I can fit on these rims. (17x8.5 front -- 18x9.5 rear) any advice would help.
Old Dec 29, 2002 | 05:57 AM
stik6shift98's Avatar
just take off bolts and bolt the new rims on........275 on back 245 on front
Old Dec 29, 2002 | 09:24 PM
Dr.Mudge's Avatar
On the rears grind either the center of the wheel or your hub about 1mm, just do it till it fits, its not much material to remove.
I know a guy with these wheels, they run fine, no backspacing issues, 18s on rear 17s front.
Old Dec 29, 2002 | 10:17 PM
MARSTAUT's Avatar
Do you happen to know what size tires he runs (Dr. Mudge)? Also, does anyone know the average cost to powder cought a set of rims?
Old Dec 30, 2002 | 03:14 AM
Dr.Mudge's Avatar
Whatever the stock sizes are, he bought the whole setup for $400. Probably 275 wide on the rear, profile 35? 40?
Fronts should be 245 or maybe 255, I'll ask when I catch him tomorow.
Old Dec 31, 2002 | 07:55 PM
ledfoot2's Avatar
Hey MANIAC! Juan got his car running tonight. We'll have to see if he kills himself at the autox this sunday
Old Jun 9, 2003 | 12:55 PM
tmills001's Avatar
I have a 98 z28 w the c5s and the rear tires seem to rub. would spacers help me at all? if so what would anybody recommend???
Old Jun 16, 2003 | 12:17 PM
MARSTAUT's Avatar
All you need to do is beat out the front inner fender well with a (big) hammer. spacers will work too, but they cost money and if you want to be safe with spacers you will also need longer studs.
Old Jun 16, 2003 | 03:23 PM
akrott1's Avatar
I have a set of 97 C5 Wheels...I had to grind a slight bit of material of the center of the rim. I am running 274-35-18 on the rear and 245-45-17 on the fronts with no rubbing or any issues.
Old Jun 16, 2003 | 06:36 PM
MARSTAUT's Avatar
you most likely wouldn't have to worry about any rubbing with 275's but I am running 295-35-18's in the back so they are a bit wider. 275-45-17's in front.
Kato
Jan 26, 2015 09:21 PM
NewsBot
Dec 28, 2014 06:20 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
