Part #'s for 1le 35mm and 21 mm antisway bars offered on the 2001 1le package?
They have a picture of all the parts offered as part of the 1le package for the 2001's on 1le.net under part #'s but they don't have any of the part #'s. I'm interested particularly in the 35mm front and 21mm rear antisway bars and related bushings. Anyone?
[This message has been edited by gamboa (edited August 03, 2002).]
I checked out http://www.slponline.html and they don't show the 35mm sway bar. There's a cheaper vendor that sells SLP parts though at
http://www.ttperformance.net/sus.shtml
After you check out the price for the 35mm sway bar I don't think you'll still want one. Try getting the 1LE 21mm rear bar from the above link, and then get the Suspension Techniques 35mm front bar from Sam Strano at
http://www.stranoparts.com
With close to stock spring rates that combo should work well for the street.
Mike Taylor
'94 Formula
Holley cold air, Borla downpipe, Walker UltraFlo catback, BMR STB, BMR PHR, Ground Control coilovers, Bilsteins, 16x9.5 Rikens, Hoosier 275/45/16 A3S03, G2 Torque Arm, Torsen T2R
<font face="Verdana, Arial" size="2">Originally posted by 94bird:
</font>
</font>
Yes, the 35mm bar from ST is a good product. You'll find a lot of the people on this board and others are using it. It doesn't work for everyone though. Mostly that depends on how you're using your car. If it's mostly for street use I'd tend to say you should try the 1LE front and rear bars since you have the Eibach Pros. For autocrossing a lot of people like a 35 front and 19 rear combo with the Eibachs or a similar spring setup.
F'n1996Z28SS
08-23-2023 11:19 PM
Z284ever
53
08-07-2002 11:06 PM
