O.E.Wheels vs AFS?
O.E.Wheels vs AFS?
Both of these companies market 17 x 11 rims on Ebay. Are there any differences between them? I know the AFS rims seem to be strong enough for road track use. How about the O.E. distributor's rims? O.E. Wheels is out of Florida and AFS is from California. On their web site AFS says the rims are made "for " them so they are not the manufacturer. Have finally decided to bite the bullet and get them but from which one?
Beware, AFS's ebay wheels are different than their "by order" wheels. I bought a set of wheels from them two years ago. They are perfect GS replicas (except for the offset that I wanted). The wheels are awesome.
I won a set from them on ebay this summer. They are Korean made, and stamped max load 1400lbs. The stars are a bit thicker and more square than the ZR1/SS/GS wheels, also the rim lip is a lot different (not just painted different). Just FYI, I also won a set of 17x9.5 silver wheels from AAA wheels. The rims are manufactured by the same company that made the AFS ebay wheels that I won.
I don't mind them for track use, as they will make good race wheels. Just, if you are looking for a certain wheel, or trying to match another set, call them up and buy the good ones.
I have a set of both. The AFS wheels are of much better quality than the O. E. Wheel Distributor's. I also like the styling better on the AFS's do to the more rounded spokes as mentioned by EastLa above. Make sure you watch the off-sets.
Originally posted by mitchntx
Me 3 ... 1400lbs loading should be more than adequate
I appreciate the concern.
OE 16" wheels are rated at 1600 lbs and FS guys are using them, running Hoosiers. I'm sure broken wheels have occured.
But just like them, I'll cross that bridge whn I come to it.
