Autocross and Road Racing Technique There is more to life than a straight line
Nitto question?
Old May 1, 2003 | 12:12 AM
CDN WS6's Avatar
Question Nitto question?
I am going to be purchasing tires soon and need some opinions. I am going to do one of four things.
1)Firestone Firehawk SZ50 EP's P275/40ZR-17 on all 4 corners
2)Yokohama AVS ES100's P275/40R-17 on all 4 corners
3)Nitto DR's on rear and Firehawks up front
4)Nitto DR's on rear and AVS ES100's up front
Which is the best street set-up? I was wondering if the DR's handle well or if they're strictly a drag radial? I might do a few 1/4 runs this year and possibly an autox or two but mainly these tires are for street use. Right now I'm leaning towards the firehawks, any opinions?
Old May 1, 2003 | 08:29 PM
chuck's Avatar
Drag radials handle pretty well, especially the 17's. I have autocrossed with Nitto DR's on all four corners. The Nitto 555RII is even better handling, and hooks up almost as well. They are only offered in a 275/40/17 though. I have been running the RII's for street tires for well over a year, and really like them on all corners. I think you will too.
Old May 1, 2003 | 09:48 PM
CDN WS6's Avatar
Thanks Chuck,
How fast do the RII's wear? I'd like a tire that's going to last around two years. I wouldn't really be abusing them so do you think they'd last 15-25000 miles?
Old May 2, 2003 | 07:24 AM
chuck's Avatar
With some autox, a little road racing and hard street driving I get 10-11K miles out of the Nittos. Since they are cheaper than most "performance" radials, and perform better, I figure it is a wash over time.
Old May 4, 2003 | 09:27 PM
AutoRoc's Avatar
yjyt
Yeah I would do RII's in the front and drags out back of equal size. You are running 275/40/17 tires on the WS6 right? If so then that will work great.
However if you want the best mileage you might want the R2's o all 4 corners so you can rotate them. They should still hook up ok at the track also since they're a sticky compound Goodluck
I'm a wierdo, I'm running 315.35.17 Nitto DR's out back with 255/40/17 Kuhmo V700 VictorRacers up front Hopefully it's balanced and competetive come race time! We'll see!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
sloppytot
Feb 25, 2015 08:30 PM
Jason Short
Jan 19, 2015 06:33 PM
96z
Aug 2, 2002 09:00 PM
