Autocross and Road Racing Technique There is more to life than a straight line
ls-1 brake upgrade
Old Oct 2, 2003 | 11:37 AM
onthemat's Avatar
ls-1 brake upgrade
Has anyone ever run into trouble with abs sensors not fitting with the ls-1 brake upgrade?
Old Oct 4, 2003 | 02:38 PM
CPZ's Avatar
CPZ
I just read a very interesting discussion about just that issue on the LS1.com forum. The LT1 hubs and LS1 hubs are different, but the sensor for abs is the same and the plug is the same. The signal to the abs sensor is the same. A guy name Bob Bishop at "lateapex@charter.net" appears to be very experienced at LT1/LS1/C5 brake upgrades.
regards,
Cal
96Z autocrosser
2000 B4C
2002 TA WS6 convertable
Old Oct 4, 2003 | 04:39 PM
steve-d's Avatar
Here it is:
http://www.ls1.com/forums/showthread...hreadid=390509
LS1.Com Forum - LS1 brakes on LT1: Will ABS computer be able to understand LS1 sensor?
Steve
Old Oct 4, 2003 | 11:48 PM
onthemat's Avatar
Thanks guys that fully answers my question. It's time to do the upgrade.
Old Oct 5, 2003 | 05:00 PM
Bralgar's Avatar
I received my LS1 brakes without hubs. I just used the LT1 hub assemblies from my old spindles since they were still in good shape, with the new LS1 spindles (knuckles, whatever) and it worked great.
Besides aren't hub assemblies like $150 each?
Old Oct 6, 2003 | 08:11 AM
CPZ's Avatar
CPZ
I used the LT1 hubs on my upgrade. They are interchangeable, but I read that the LS1 design has a bearing upgrade. I plan on running my LT1 hubs until I have a problem (if ever).
regards,
Cal
96Z C-Prepared autocrosser with LS1 upgrade
2000 B4C
2001 2500HD Silverado 4x4 6.0
67 Vette coupe prostreet
Old Oct 9, 2003 | 07:17 PM
bigdreamZ's Avatar
Perhaps at a dealership, I got my LS1 hubs off ebay for 26 bucks
In answer to the original question you should not have a problem.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
QuickSilver02
Apr 7, 2015 11:12 AM
Jazsun
Dec 29, 2014 12:14 PM
