Autocross and Road Racing Technique There is more to life than a straight line
Lowering and alignment?s
Old Jun 8, 2002 | 04:42 PM
JeffsWorld's Avatar
Question Lowering and alignment?s
Well, I finally found someone who will install my Hotchkis springs (1" drop). I bought them on a gp 2 years ago and have been sitting on them because no one would touch them. My question is will I need to get the car aligned after the drop? If so, what are the recommended settings I should tell the tech? or should I just let him figure it out? thnx
1996 Blue-Green Chameleon Formula
1of70 Chameleon Formulas for 1996
2000 S10 LS 4.3L 4x4 PickUp
JeffsWorld
Old Jun 8, 2002 | 08:22 PM
LPEdave's Avatar
Post
Yes, you should get an alignment after the install. The specs kind of depend on what you're doing with the car. If it's a street car, you could just have it set to the stock alignment. But if you're taking the car onto the track, or want a bit better handling, you'd want to put some camber into it (-1 degree, more if you're running mostly on the track), then as much caster as you can, and zero toe.
I just had mine aligned this morning to -1.4 camber, 3.7 caster, zero toe. It's a track-only car.
Dave
1997 LPE 383/n2o Camaro Z28 Convertible
12.39@112.2, 1.76 60' (na) 11.27@124.6, 1.76 60' (n2o)
LT1 Diagnostics, New to Nitrous? Northern California Racing Club
Old Jun 9, 2002 | 07:36 AM
93zder's Avatar
Cool
I just had my Z aligned a couple of weeks ago. I had then set it to
-1 camber; +3 caster ; 0 toe
This truly made a seat-of-the-pants difference in handling. I only wish i did it sooner!
My Z is mostly a daily driver, and doesn't see any track time, by the way.
1993 red M6 Z28; custom control arms; bushings; strut bar; Eibach Pro-kit;17" rims & 275 tires; Mac exhaust; K&N cold air; airfoil; TB bypass; 3.73 gears; KVR pads & rotors; -1 camber alignment
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
alliance12364
Sep 23, 2015 12:40 PM
