Autocross and Road Racing Technique There is more to life than a straight line
Lowering
Old Dec 9, 2002 | 06:49 AM
mc63's Avatar
Lowering
I'm planning on installing Eibach springs and Bilstein HD shocks, will I have to replace the panhard rod to compensate for the body being lower?
Thanks,
Michael
Old Dec 9, 2002 | 03:41 PM
Dr.Mudge's Avatar
Apperantly lowering the car doesn't offset the rear that much, LCAs would be needed though if you want to actually 'race' the car fast, after lowering my car besides the alignment being WAY off the LCA position was very much screwed up.
Old Dec 9, 2002 | 05:24 PM
94bird's Avatar
If you're running stock sized tires I doubt you'd have a problem. There is a little side shift in the tires when you lower the car, and if you're running 315/35 tires on 17x11 wheels, clearance can be an issue.
Old Dec 9, 2002 | 10:46 PM
I CORNER1's Avatar
Ditto.
I ran a Hotckiss non-adjustable panhard rod bar with my car lowered on Eibach Pro springs. However, I had to switch to an adjustable PHR bar to get adequate clearance with the 315mm tires added later.
Old Dec 10, 2002 | 12:03 AM
94Zman's Avatar
ST 1.2 & 1.7 drop in the front and rear is just fine.... but a little low for me
n2oblkz
Oct 22, 2015 02:31 PM
n2oblkz
Oct 12, 2015 01:53 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
alliance12364
Sep 23, 2015 12:40 PM
