Autocross and Road Racing Technique There is more to life than a straight line
Just got back from my first autox!!! Tire questions for my size...
Old Jun 10, 2003 | 12:17 PM
CARGUY's Avatar
Exclamation Just got back from my first autox!!! Tire questions for my size...
Just got back from Solo2 two day school out at Norton Airforce base in San Bernardino in CA, it was a BLAST!!! On to my tire question... I have 17x9 (front) and 18x9.5 (back) for rims, currently the tire size I have is 255 40 17 (front) and 275 35 18 (back). I now know I want more size up front, so I was thinking of 275 40 17 front which I know is ok due to it being the same rim/tire combo size on the SS, but would it be ok to go to a 295 35 18 on the rear 9.5" wide rim? I realize I am keeping the same staggerd ratio more or less, but I felt the added width on the front would make a nice difference. The car felt pretty neutral overall. So what do you think?
Old Jun 10, 2003 | 04:04 PM
1Z2Z's Avatar
What wheel width do they recommend for the 295?
If it will go on, I'd get it. I'm wearing out a set of 255 hoosiers, and when they are gone I know I'm going to a larger tire. Mike
Old Jun 10, 2003 | 04:24 PM
CARGUY's Avatar
Shoot, I just checked and 10-11.5" is recommended.
Old Jun 10, 2003 | 09:47 PM
bruecksteve's Avatar
Go to TireRack and pick a tire. Then click on specs and most of them have the design wheel size.
Old Jun 11, 2003 | 05:36 AM
Norm Peterson's Avatar
Design rim width is only the width of the rim on which the tire dimensions were measured (it may be referred to as "Measuring Rim Width"). Tire Rack specs also list the mfr's recommended range of rim widths; for auto-x (and high performance cornering in general) you want something up at the wider end of that range unless you are constrained either by class rules or by major problems with available offset and/or "it won't fit" issues.
Norm
Old Jun 11, 2003 | 06:36 AM
The range is what I was referring to. I could run my street 275's on my 11" wheels. It would be an interesting test to see how the 275's on 9.5" and 11" compare to 315's on 11". Might not be as much of a difference as you might think. Then again.....
Old Jun 11, 2003 | 12:14 PM
CARGUY's Avatar
I wouldn't think a 295 on a 9.5" would buldge that much? I was looking at Kumhos website at the ECSTA MX.
Old Jun 11, 2003 | 12:35 PM
I wouldn't. Too much tire for the rim size. Not only that but you're not gaining much in the rear: (all approximate)
255 = 10.0"
275 = 10.8"
295 = 11.6"
315 = 12.4"
Old Jun 11, 2003 | 01:02 PM
CARGUY's Avatar
Do you think I should stick with my current sizing or go with 275 all around? I just thought it would be wierd to have 275 all around due to the staggered rim sizes in both diameter and width.
Old Jun 11, 2003 | 01:19 PM
I would definitely run 275's in the front (which is almost too large for a 9" wheel) but with a 9.5" width in the rear, I would not go wider than a 275.
Old Jun 11, 2003 | 01:27 PM
CARGUY's Avatar
SS wheels are 9" and they were 275 right from the factory?
Old Jun 11, 2003 | 01:40 PM
You're right. But they are borderline as far as size. It's not that it won't work, it's just not the optimum setup.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Hurin
Dec 13, 2014 07:38 PM
Snoman73
Nov 17, 2014 07:22 PM
