installed springs/struts and now i have a knock!!!
i installed some SLP springs off a camaro SS. i also installed new front struts at the same time and they are just the SLP take off (DeCarbons). are these shocks not compatable with the springs in installed? i have a serious knocking noise which i can not feel in the steering but i can certainly hear it inside and outside the car when hitting common bumps in the road and even the little cracks across the road causes racket under my car! i hope i don't need to shell out more cash on after market shocks and be out $75 on the take offs.
i don't know much about suspension combinations so i'm hoping you guys can help me,
thanks,
michael.
thanks,
michael.
Originally posted by Chewbacca
Did you get that top nut tight enough? I've done that before. Made a similar noise by your description.
*shrug* Just something to check.
i will try to check that if it ever stops raining and will see if that helps. i'm kinda hoping its the new swaybar bushings, spacer and bolt kit i put on. that could cause it to do the same noise on both sides, i think.
what do you think about that?
Yup.
Mine knocked and clunked after my Bilstein install. Right after this I assisted on a similar install with another car. We tightened those all the way down.
I thought this may be the source of my problem so I bit the bullet and took 'em back off. Tightened the nut AT MOST two turns. Presto. Absolutely no noise from the front end.
This was just my car. Your results may vary.
Yup.
Yup.
