Autocross and Road Racing Technique There is more to life than a straight line
how do i tell if the bars are hollow or solid
Old Nov 13, 2003 | 08:06 AM
Tom R.'s Avatar
how do i tell if my sways are hollow or solid without removing them.
i forgot the formula for Pi (maybe i will go to my 25th and see if any teachers are there that would know ). is there an easy way to measure the diameter (besides looking at the receipt which i dont have)?
Old Nov 13, 2003 | 09:14 AM
Jeff94TA's Avatar
Not sure how to tell hollow from solid without removing it to see how much it weighs. There is a dramatic weight difference between the two.
For diameter you can take a piece of string and wrap it aroud the bar one time and then measure that length.
32mm = 3.96"
35mm = 4.33"
Here is the math I used: 32mm/25.4mm per inch = 1.26"x3.14(Pi) = 3.96" circumfrance.
Old Nov 13, 2003 | 01:09 PM
Sam Strano's Avatar
You can usually look at the ends of the bar and tell. Hollow bars have a seam where the ends of the tube are crushed down. Solid bars are well, solid....
Old Nov 17, 2003 | 12:30 AM
LPEdave's Avatar
Another way to measure the diameter... grab an adjustable crescent wrench and tighten it down around the bar. Pull it off and measure it. Or if you have a set of open end wrenches, find the one that fits around the bar...
Dave
Old Nov 18, 2003 | 09:30 AM
bruecksteve's Avatar
OR.... just order a 35mm solid from Sam, then it won't matter anyway!!!!
Old Nov 18, 2003 | 10:47 AM
Tom R.'s Avatar
tempting as that is, this is my station/commuter car! before I order anything i wanna know i am getting the bugs out of the rear ride.
BTW, it rides much better with the salad shooters than it did with the 17" SS/SLPs. or maybe im just getting used to the solid axle.
i have to confer with the minister of finance (aka she who must be obeyed) before i order anything.
IndyZman
Oct 22, 2015 02:17 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
