Autocross and Road Racing Technique There is more to life than a straight line
HOTCHKIS vs bmr
Old Feb 9, 2004 | 07:10 AM
Coolformula's Avatar
HOTCHKIS vs bmr
HOTCHKIS or bmr lca's which ones are stonger /better??? thanks
Old Feb 11, 2004 | 09:16 PM
locosteelersfan's Avatar
Both comps have their fans.
However I have never seen anyone
bad mouth Hotchkis like many do BMR.
Hotchkis and G2 are generally considered
top end products while BMR is low end.
Not flaming here just stating common
opinion that may or may not be deserved.
I have several Hotchkis pieces and no BMR.
I got G2 LCA's
Old Feb 14, 2004 | 10:47 PM
OBE1 95Z28's Avatar
I just switched from Hotchkis boxed LCAs (poly/poly) to Global West sperical/poly combo. Do a search and you'll read about binding caused by poly/poly ends. The sperical/poly combo will keep the suspension from binding yet not have the harsh vibration of a LCA with sperical joint on both ends. I also like Global West's design in that the sperical joint is located inside a metal loop; if the joint was to fail, the loop should keep the rearend in place until you get the car stopped.
football4life
Oct 4, 2015 07:48 AM
JJOHNROE
Sep 8, 2015 05:39 PM
97blackformula
Aug 27, 2015 06:02 PM
Slayer
Aug 17, 2015 03:55 PM
realistyc
Jul 28, 2015 07:32 PM
