Help picking suspension components
My car is an original WS6 and had the 1LE (I think) springs on it. I thought I wanted to set up a mainly drag racing car and put the HAL/QA1 shocks and springs on it. Since I don't go to the track that often and with the car being a 6 speed I have decided to set it up for corner carving. I don't plan on doing any auto-x, but want to be able to take highway entrance ramps at 70+ mph with very little body roll.
This is what I have:
Can you guys give me some recommendations on what I should purchase? I plan on doing the C5/ZO6 brake upgrade also.
Thanks.
- DeCarbon Shocks
- 1LE Springs
- 19mm stock rear sway bar
- 25mm front sway bar (I think?)
- BMR chromoly adjustable panhard rod
- Spohn chromoly adjustable lower control arms
- Spohn LCA relocation brackets.
- Stock torque arm
- All poly bushings
Thanks.
as stated above.
a strut tower brace and a set of sway bars. i got the BMR 32/21mm solid bars w/ all poly bushings and endlinks for about $325 shipped i think. good quality stuff and it made a HUGE improvement on my cars cornering ability (even with stock springs/shocks)
something that is also very important is a decent set of tires, if you don't have good grip on a corner, all the suspension mods in the world aren't gonna do crap
suggestions:
firestone firehawk SZ50s
g-force kdw (kdws if you need all season...if not required the kdw give much better grip)
suggestions:
Copied and pasted from another post.. Heres what I have and my opinion
Stock springs
Bilstein HD's 297 shipped from some bmw dealership
Have Sam Strano revalve them for you if u want alittle better performance out of them
32mm front sway bar
19mm stock rear sway bar..
I have a subframe connectors, strut tower brace, poly bushing panhard rod and 17x9 SS rims with good rubber.
The sway bar made a big difference. Thinking of going 35mm but i dont want to hurt my launches.
Bilstein HD's made a big dfference.
Then the 17x9 rim with good tires made a big difference too..
Most important to me are the tires, and the sway bar, Bilsteins are icying on the cake, and the other stuff are the candles.
Stock springs
32mm front sway bar
NewsBot
Mar 30, 2015 12:40 PM
guionM
32
Aug 19, 2002 01:39 PM
