Autocross and Road Racing Technique There is more to life than a straight line
HAL install
Old Jul 15, 2002 | 08:06 PM
MislMan's Avatar
Post HAL install
Fixing to install HAL shocks on the front using HAL springs. I have done a search on this as well as looked at a couple of other sites with no clear answer. What I need to know is what is required to be installed on the top of the HAL shock rod when installing using their springs? Can you just slide the rod up through the stock mounting plate or do you have to place a spacer of some sort on the rod before the install? The instructions are not very clear on this and HAL doesn't answer my emails. The stock dust boot does not fit over the rod nor inside the springs. Any help would be appreciated, pictures would be even better.
Thanks!
Later ... Larry S.
'95 Trans Am - Powerdyne
11.874 @ 118.92 MPH
Nov 18, 2023 07:21 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
1996LT1Z28
Apr 14, 2015 07:15 PM
MislMan
Jul 19, 2002 11:41 AM
