Hal gen F shocks, and BMR springs?
I was looking at the HAL Gen F shocks, and BMR springs.
I think they might be better then the Slp stuff.
and I want the adjustable shocks the most.
I really like palying hard in the corners, but still want a good hook at the track.
I think this with the BMR adjustable PHB with poly bushings, and the bmr LCAs with poly poly (or would poly/rubber be better)
Will make a great combo, and great compromise
plus I think with the adjustable I can "kinda" make the ride softer for long trips?
I"ve heard mixed reviews about the Hal shocks. I recommend if you want adjustable to go with Konis, they are great.
Stay away from AGX, I ran them full stiff and they busted (6 months) quick.
I've had my Konis for 2 years now, and I run them full stiff all the time. Unless I'm at the drag strip.
I got my Konis at tire rack, but I'm sure Sam Straino can hook you up (he's a sponser on here I think) I bought the Single Adjustables. I didn't want he dual adjustables, I didn't want to be that technical.
As for AGX, they are KYB shocks. They are cheap, and cheap they are...
Go to www.stranoparts.com There is a koni/bilstein set up that sam has put together that are award winning. That is the route I am going to go. I've heard the biltein HD's can be "harsh" and the KYB flat out aren't worth the headache. The koni/bilstein setup, after researching, are the way to go...atleast for me.
something thats not going to lower my car too much.
CamaroHeed
Mar 18, 2020 09:50 PM
