Autocross and Road Racing Technique There is more to life than a straight line
Brake Compairison
Old Jan 7, 2003 | 03:43 PM
Xscream's Avatar
Brake Compairison
Intresting reading for you guys that care about brakes
Man Application Price Min. Wheel Size Rotor size (mm) Pad Area(Sq. cm) Street Designed Rotor Replacement Price All needed Spacers DOT Approved Stainless Brake Lines Brake Fluid Wheel Studs
Brembo 93-97F Body N/A No
98-02F Body $2995.00 17" 332x32 48.4 Yes $333.15 N/A Yes No N/A
Wilwood 93-97F Body No
98-02F Body $1342.37* 17" 330x32 37.7 No $238.20 N/A No No N/A
Mov'it 93-97F Body $2695.00 17" 330x34 81.3 Yes $300 No Yes No
98-02F Body $2695.00 17" 330x34 81.3 Yes $300 No No
Prospeed 93-97F Body $1995.00 17" 330x34 81.3 Yes $220.00 Yes Yes Yes Yes
98-02F Body $1995.00 17" 330x34 81.3 Yes $220.00 Yes Yes Yes Yes
Baer/Alcon 93-97F Body $2845$3725** 17" 332x32343x32 64.582.1** Yes $245.00 N/A Yes No N/A
98-02F Body $2845$3725** 17" 332x32343x32 64.582.1** Yes $245.00 N/A Yes No N/A
Stoptech 93-97F Body N/A
97-01C5 'Vette $2595.00 18" 355x32 67.2 Yes $279.00 No Yes No No
Factory LT1 43.5 Note: The shapes fo the GM pads is VERY far from being as square as the other pads above. These specs are a little less acurate than the other pad specs. Nonetheless, it still provides a relatively close comparison.
LS1 52.2
C5 52.2
* This is the Wilwood"basic" kit. it does not include the heat barrier 2 piece pistons. The "Roadrace" kit that includes stainless steel lines and Aluminum pistons with Stainless Steel sleeves is $1840.29.
** Baer/Alcon has a 4 piston and a 6 piston caliper available. The second numbers are for the 6 piston kit.
For a comparison of these pad areas to Porsche models: Compare these pads sizes to the "Big Brake" kits by Brembo and Wilwood. Notice the $3000 Brembo kit is just slightly larger than the smallest and earliest Porsche 4 piston caliper. And the 6 piston Wilwood is 20% smaller than the smallest Porsche. Even the Stoptech kit is approximately 20% smaller than the Mov'it and Prospeed kits.
Model Year Pad Area (sq. cm)
911 Turbo (930) front 1977 46.3
964 C4 front & rear 1989 46.3
928S4 front 1987-91 67.2
928S4 rear 1987-91 46.3
944 Turbo S front 1988-89 67.2
944 Turbo & Turbo S rear 1986 - 89 46.3
911 Turbo front 1991 - 92 67.2
911 Turbo rear 1991 - 94 46.3
911 Turbo front 1994 80.3
993 Twin Turbo front 1996 - 98 80.3
993 Twin Turbo rear 1996 - 98 67.2
996 Twin Turbo front 2001 - 02 81.3
996 Twin Turbo rear 2001 - 02 73.6
996 GT3 Cup front 2001 - 02 81.3
996 GT3 Cup rear 2001 - 02 73
Old Jan 8, 2003 | 03:45 PM
lateapex's Avatar
For accuracy's sake, the pad area listed for the C5 front pads is incorrect. The correct area is 72 sq. cm. The corrected version of the chart copied above is at: http://prospeedmotorsport.com/brake_kit_compare.htm
Bob Bishop
Old Jan 8, 2003 | 04:38 PM
RdRacerZ28's Avatar
The C5 caliper has quite a bit of pad area.....I've been using them on a few cars latley. Put some on a 3rd gen car and a 4th gen. For the $$$ it works wonderful. Tons of pads available also.
Old Jan 8, 2003 | 05:32 PM
I CORNER's Avatar
I have had the BAER GT+ kit installed for about 9 months.
It uses the Corvette C5 style calipers (very large for a 2 piston) and 13.15" by 1.25" 2-piece rotors with aluminum hats. They fit my 17" ZR1 and SS wheels fine with the exception that I have to make sure that the shop goes easy on the stick-on balance weights in the caliper area. They came with stainless lines.
These brakes are amazing!! Stock brakes were hard to get into the ABS on street tires. Now I can still get ABS operation on my R-compound Kumho Victoracer 700s.
I haven't measured the pad area, but it is very large. Also with C5 brake calipers, I can get pads from anywhere ... no special order Brembo, BAER Alcon or Wildwood pads needed here.
Old Jan 10, 2003 | 08:51 AM
Xscream's Avatar
Bob Bishop
That is mike from Prospeeds chart that I posted... I wonder if he updated it
Old Jan 10, 2003 | 08:53 AM
Xscream's Avatar
The Baer Kit is actually a Alcon product. Baer is there "street" or consumer baised product line. On almost all brembo product you can buy it from the Porche dealership if you know there part numbers.
Old Jan 10, 2003 | 08:57 AM
RdRacerZ28's Avatar
They also have a kit that uses the C5 caliper Josh....
Old Jan 10, 2003 | 09:03 AM
lateapex's Avatar
The Baer GT+ system that ICORNER mentioned is based on the GM C5 caliper, which is built by PBR. That brake system doesn't have any Alcon parts in it.
Bob Bishop
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
