Autocross and Road Racing Technique There is more to life than a straight line
alignment FAQ?
Old Dec 11, 2003 | 07:03 AM
john storie's Avatar
alignment FAQ?
is there a FAQ somewhere?
one for lowered cars, and one for stock height cars?
the daughter's 93 is wearing out the shoulders.
what would be nice is a usable range, that's what i did last time, just compiled all the posts (including Sam's input) and gave the tech that range, and he hit it best as he could, without taking all day.
as usual, my HP pos crashed and lost that data.
here's what I intend to give the tech this time, got this by searching and cut & post out of threads
Caster - +4.5
Camber - max negative
Toe - slight toe out. Sam's recommedation is 3/32 total toe out
Camber -1.5
Caster +4.5
Toe 1/16th in
-1.5 camber
4.7 caster
0 toe
Camber 1.5*
Caster 4.3*
Toe In 1/16"
Old Dec 11, 2003 | 08:07 AM
bruecksteve's Avatar
Since she doesn't race I'd recommend:
Max negative camber (it won't be much anyway)
4 degrees caster
1/16 toe in
Old Dec 11, 2003 | 05:48 PM
tks. i think i got some them specs off one your posts...remember your avatar..
Old Dec 13, 2003 | 05:50 PM
Acct 23749's Avatar
Well i would like to know what people are running for camber.
Many people say to just max it out....im not sure where it puts it tho...
I have the BMR k-member and A-arms, and they allow for a ton of adjustment.
I am supposed to have ~ -1.3 camber, 5.1 caster. but i dont exactly like this.
ITs handles very well, but i have sacraficed alot of straigt line breaking. I guess the way the wheels make contact on the road when the wheels are so far tilted reduce the cotact patch, at least in a striaght line.
is it suppose to be this way? what would be a good balance of handling and braking?
Old Dec 13, 2003 | 06:13 PM
It all comes down to what you're going to be doing with the car???
Old Dec 14, 2003 | 09:49 AM
V6Bob's Avatar
"the daughter's 93 is wearing out the shoulders."
If that's your concern, note that the autocross combination of maxed out negative camber and some toe out, when used for normal driving, will wear the edges faster. Moreso as the load in the car is increased.
A decent alignment guy will know what the problem is by looking at the tires. I believe GM alignment specs are pretty good for even tire wear. In particular, zero toe is a good idea for that.
Old Dec 14, 2003 | 01:48 PM
The question is, is it wearing the inside shoulder or the outside shoulder???
Mir Hussain
Outside of United States
Aug 8, 2015 07:00 PM
jasonduaine
Jun 4, 2015 09:29 AM
achipfef
May 5, 2015 10:20 AM
Hurin
Dec 13, 2014 07:38 PM
jgeorger
New England Area
Aug 15, 2002 09:56 PM
