Autocross and Road Racing Technique There is more to life than a straight line
adj panhard install question
Old Sep 15, 2002 | 12:57 PM
818camaro95's Avatar
I have adj bmr panhard rod, I got it used and need a little help insalling it. Thanks Yes I need help installing the adj bar.
Old Sep 15, 2002 | 02:39 PM
LPEdave's Avatar
You might post in a regional forum...
Dave
Old Sep 16, 2002 | 01:05 PM
Serial Thriller's Avatar
Do you mean you need help physically installing it (that seems to be what Dave meant), or info to help you with details of the install process?
Old Sep 21, 2002 | 12:22 AM
trackbird's Avatar
BMR Panhard Install
I have that bar on my car (Chromoly race version with Chromoly rod ends). Feel free to drop me a line, I'll answer anything I can.
Old Sep 22, 2002 | 06:10 AM
traces95z
Guest
Posts: n/a
Take the old one off
Put it up to the new bar so the holes line up
Put new bar on
Measure both sides from one point on the bar to the wheel well. Do it on both sides from the same point on the corresponding side. Make sure all is equal.
Put some Loctite or other thread locker fluid on the threads where the adjuster bolts are so they don't come loose.
Your done
Old Sep 23, 2002 | 10:24 PM
97f1z28's Avatar
ok i am doing the same install. it sounds easy just one more question. Can i do it with the wheels in the air or should the suspension be loaded?
Old Sep 24, 2002 | 05:05 AM
traces95z
Guest
Posts: n/a
You can always jack up the car (and put on jackstands) to just put suspension pieces on (leave bolts very loose), BUT then lower the car to the ground (so it is loaded) and THEN tighten the bolts.
Always tighten stuff up when loaded, including SFCs, LCAs, torque arms, and sway bar end links.
Other input welcome.
Old Sep 24, 2002 | 08:42 AM
LPEdave's Avatar
Hmm.... too general for me. I agree with all but the torque arm, I don't think I'd set the car on the ground with a loose torque arm. Then on the "do it in the air" list I'd add shocks & springs.
Dave
87Aerocoupe
Jan 10, 2015 07:27 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
