Yet another Clear Corner Comment
Old Oct 6, 2002 | 05:23 PM
Ernster500's Avatar
What is up with the Diamond clears from Procarparts?
They aren't seating properly and I've had to grind them down to seat correctly. The drivers side light still has a gap on the bottom. I think the bump where the vertical screw goes in is holding it up. I have ground down the bump but I still have a little bit more to go.
What a PITA! So much for "direct fit"...
I took a break to come in here and rant!
E
Old Oct 6, 2002 | 05:30 PM
pu12en12g's Avatar
You know what, I had a similar problem with the APC style (NON-Diamond Clear) corners. It turned out that I eventually got them to fit like they were supposed to, without grinding anything down. But I was sure I was gonna have to grind away... the only thing I can tell you is to make sure to have alot of light on the subject when u are installin' them. Until I could see EXACTLY what I was doing under there, I was sure they wouldn't fit correctly.
Old Oct 6, 2002 | 10:53 PM
Chrisbequick's Avatar
Mine fit just fine.
-Chris
Old Oct 7, 2002 | 02:26 AM
PaulN64's Avatar
no fitment problem with mine
Old Oct 7, 2002 | 07:05 AM
JackZ.Twenty8's Avatar
Sorry buddy, but mine fit fine as well!
Old Oct 7, 2002 | 07:07 AM
cryptopsy's Avatar
mine fit fine as well. I also drilled a hole in the housing like suggested and I have never had any condensation inside the housing.
Old Oct 7, 2002 | 02:57 PM
Ernster500's Avatar
Hmmm, that's interesting. I wonder if I just got an irregular set. Of course the stock lights were a perfect fit. The passenger side fit fine. I know there is nothing keeping the driver's side light from fitting in the openning. I guess I'll just have to play with it a bit.
Oh well, somehow I'm sure this all builds character.
Thanks for the responses!
Old Oct 7, 2002 | 03:36 PM
blue95's Avatar
actually come to think of it mine didn't fit so well either......they eventually went it but not without some persuasion. And yes I know a exact fit when I see one.
Old Oct 7, 2002 | 06:57 PM
98 Z28 A4 LS1's Avatar
Mine went in OK...not that it was an easy install in the Mississippi humidity though.
Old Oct 7, 2002 | 10:01 PM
Srper's Avatar
Oh Boy, mine are coming in on Thursday
Old Oct 9, 2002 | 09:11 PM
White Z 4 Show's Avatar
I get mine on the 16th...hopefully direct fit. Anybody installation instructions?
Old Oct 9, 2002 | 10:28 PM
PaulN64's Avatar
since we have no idea what year your car is, if it's a 93-97, you'll have to come from the bottom of the car. Take out all the plastic parts around the air dam and the air dam itself. You can also do the same for the 98-up, but most people find it easier to just remove the headlights.
Old Oct 10, 2002 | 02:11 AM
chesee48's Avatar
mine wasnt 100% perfect...but it was very close..
Old Oct 10, 2002 | 02:40 AM
Bawls's Avatar
Mine when in <Jim Carrey>l..i...k...e... a... gl..oo...ve... </Jim Carrey>
Some pics I took of the shizzle.
http://www.vorliant.com/z28/exterior/blur.jpg
http://www.vorliant.com/z28/exterior...s/at_night.jpg
http://www.vorliant.com/z28/exterior...rs/z28-007.jpg
Old Oct 10, 2002 | 10:00 AM
93Z286Speed's Avatar
I get mine either today or tomarrow.. payed 12.95 off ebay for em cuz the person said they didnt fit.. im guessing they had the same problem as you guys.. and im here to take advantage I hope there not that hard to put on.. i dont wanna take 2 hrs to put some lights in lol
