yellow headlights and fogs
Old Mar 14, 2003 | 12:24 PM
CrAkD X 95TA's Avatar
hey Ive seen people change their headlights to bright yellow ive specifically seen it on a sunfire...i was thinking i wanted to do it to my TA...both pontiac so i figure as long as i got over the sealed beam issue for the headlight i could get the same bulbs used in the sunfire. anyone due this?
Old Mar 14, 2003 | 12:37 PM
CamaroCasanova's Avatar
Arrow
You better check local laws-I put yellow PIAA's for headlights and yellow fogs for mine-looked awesome BUT is a HUGE cop-magnet.
Old Mar 14, 2003 | 12:46 PM
ill start with the fogs.......where could i buy the bulbs?
Old Mar 14, 2003 | 01:21 PM
94BlackBowtie's Avatar
I believe your car takes a 880 fog light bulb???
Cross references (bulbs that will fit the opening, but may be angled different and almost definiately have different wattages, are 890, 892, 893, 884, 885, 899.
Search on Google, MSN, anywhere else you like to search for yellow "XXX" bulbs (XXX=number) and you should find some. When all else fails, try e-bay.
The only ones I know of btw that are yellow are the 885's that AutoOptiks sells here. 885 is the stock Camaro replacement bulb and is 50 watt I believe, which is probably enough to melt your plastic housing/lens.
Old Mar 14, 2003 | 01:37 PM
pu12en12g's Avatar
Here is what I did last year:
http://images.cardomain.com/member_i...8_104_full.jpg
http://images.cardomain.com/member_i...8_105_full.jpg
IndyZman
Oct 22, 2015 02:17 PM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Greg88
Sep 20, 2015 07:14 PM
Sep 18, 2015 03:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
