Will fuel eat rubber hose lines???
Old Jan 19, 2005 | 01:01 PM
350 HRSS's Avatar
Hey all,
Just a few quick questions. Will fuel eat the rubber hose away inside stainless steel fuel lines? Do I have to use teflon lined hose? That is what a vendor told me that I had to use if I wanted to use stainless braided hoses for the fuel supply and fuel return. I figured the teflon lined hose would be for nitrous, alcohol, or special situations. I didn't think regular 90-93 octane would eat rubber hose.
If anyone has some experience with this, I would appreciate it.
Thanks!
Old Apr 8, 2005 | 09:47 AM
Anniversary-Z-man's Avatar
Re: Will fuel eat rubber hose lines???
Whatever you do....do NOT use Teflon lined hose for fuel....go check out Aeroquip AQP braided lines or their socketless hose, there are 2 different types of hose....one is compatible with fuel the other is NOT. Make sure the hose you buy specifically says it works with fuels!
- Joel
Old Apr 8, 2005 | 10:51 AM
350 HRSS's Avatar
- Joel
This thread is quite old, so I will let you know the update. I had to replace the so called *fuel* rubber stainless steel hoses that were on my car. You could smell fuel very badly when you just went in the garage. THERE WERE NO LEAKS. Rubber hose IS NOT WHAT you use for FUEL injected cars.
I talked to www.performanceplumbing.com And you are supposed to use Teflon line hose for fuel injected cars. I didn't listen the first time, and bought regular stainless hose. I paid for that mistake. I ended up having to call them back, and order the teflon line.
A fuel injected car will eat right through rubber hose and ruin your injectors.
I can send you a piece of this stainless line for proof if you want. All of Summit's fuel line is mainly for carb. cars. You can run reg. hose w/ those.
You can even go to Advance Auto, and ask for fuel line, and they will ask you if it is fuel injected or carb. Thave have TWO different kinds. And the fuel injection line states it on the line itself, and has a lining inside for the fuel-teflon. It is also about $3-4 a foot. The stainless teflon lined that I bought from the website above was about $9 a foot.
Not trying to cause an arguement. Just check out the website, call the number and ask questions if you have doubts.
Thanks for your opinion!!
HectorM52
Jul 30, 2017 11:46 AM
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
redleader
Jan 22, 2015 12:05 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
crazypurgatory
Jan 12, 2015 10:45 PM
