will 1995 t tops work on a 93?
Old Mar 9, 2012 | 08:34 PM
1994B4Ct's Avatar
i recently picked up a t top conversion kit for my 1993 camaro z28
i got everything from two different people,
1 guy i got everything but the t tops and headliner (came from a 1998)
the other guy i got the t tops from (came from a 1995)
will the 1995 t tops work with the 1998 brackets??
it looks like the pins are smaller then the hole that the bracket has, i just dont want any vibrating and noisyness when i do this,
and im also looking for a pair of t top locks with atleast 1 key, or if you have a pair of locks with no key ill even take those if theyre free,
Old Mar 30, 2012 | 08:16 AM
94QuasarZ's Avatar
Re: will 1995 t tops work on a 93?
They should work, as far as I know all that stuff is pretty much the same. Post a thread about this in the parts wanted section as well, you should be able to get your hands on a set of locks there. Hope this helps.
Old Mar 30, 2012 | 11:55 AM
TKTMAGNT's Avatar
yes they will work, the ttops are the same design from 93-02. the only difference is that the earlier LT-1 cars had a dotmatrix design on them
Old Mar 31, 2012 | 06:04 AM
alex-z28's Avatar
Only 93s had that design.
calaban
May 18, 2020 06:43 PM
joe777107
Dec 1, 2014 09:32 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
