Why wont wagon wheels fit my t/a?
Old Feb 1, 2004 | 03:54 PM
iiiezekieliii's Avatar
I just got some wagon wheels for my 95 T/A, I proceeded to install them but the studs are too short... i thought they were supposed to bolt right in. I have factory wheel locks, think that may be the problem? I was thinking of replacing the studs with 2.25 inch studs... what should i do?
Old Feb 1, 2004 | 04:50 PM
chuckys95's Avatar
take a Dremel and open up the center hole (hub hole) a little bit, corvette and 98 and new Trans ams and camaros have a slightly smaller hub holes in their wheels.
Alot of people have done this (enlarging the cent hub hole) with a dremel with a grinding wheel on it.
Old Feb 1, 2004 | 05:08 PM
even with the larger hole i think the stud length would still be a problem... so would you recommend replacing the studs with longer ones? THe ones i have on there right now have like no tread on the tips im guessing because of the nuts that came with the wheels. Should I also replace the nuts?
Old Feb 1, 2004 | 08:19 PM
nothingeined's Avatar
Just grind the hole. I was going to switch wheels on my V6 with a 97 Z28 that SS rims, and for mine to fit, they had to grind the wheel to fit on the 97. Do it and it will work. Unless I am reading it wrong.
Old Feb 1, 2004 | 08:59 PM
does it have to be all even and very preisce? How much should I take off all the edges? Im asking so I dont totally screw it up and ruin the wheels... also can i use the stock lug nuts or to i have to get special ones?
Old Feb 1, 2004 | 09:09 PM
You should be able to use the lugnuts. Just get a dremel and you should be in business. The way the dude was grinding it, I don't think it was precise lol. Also since I had to pass on the awesome deal, I put them back on my ride and they were the same way on the ride back home. Just make sure it sits even. Guy grinding it with a medium bit and was there for like 2 minutes going in complete circles so one place would not be over grinded.
Old Feb 1, 2004 | 09:32 PM
cool, do you have the lugs with that special threading on the outside of it for the plastic caps?
Old Feb 1, 2004 | 09:41 PM
Yeah. It like you place the lugs on, then the center cap goes over them. Then just screw the plastic covers over the lugs to complete the look.
Old Feb 1, 2004 | 10:02 PM
Cool, ill go ahead and try it tommorow, hopefully the damn thing will work and I wont have to get new studs and stuff
Old Feb 1, 2004 | 10:05 PM
You won't. Just keep an eye on it and everything should work out.
Old Feb 2, 2004 | 01:27 PM
Black_Z28's Avatar
Do they fit on the front of the car? If so, grinding out the wheels probably isn't your problem. You should only have to grind the rear wheels, because the LS1 axel is just a little bit smaller than the LT1. The front hubs are the same.
Old Feb 2, 2004 | 05:23 PM
They fit fine on the front, so Ill start filling away right now.
Old Feb 2, 2004 | 07:00 PM
Black_Z28's Avatar
Alright, then your axle is your problem. You shouldn't have to remove too much to get them to fit too. Just grind at them a little bit then try them on the car. Keep doing it as needed.
Old Feb 2, 2004 | 07:44 PM
Pandamonkey's Avatar
I used to love wagon wheels when I was a kid.
They seem so small now..........and thin too - I swear they had way more marshmallow when I took them in my lunch in grade school.
I think I'm getting ripped off........
Old Feb 2, 2004 | 07:56 PM
Lt1 and Ls1's Avatar
Post the pics after the wheels are on your car.
