Where to get the clear corner lenses ?
Old Jun 12, 2003 | 11:37 AM
96SilverRam's Avatar
Cool Where to get the clear corner lenses ?
Does anyone know of a website I can order the clear corner lenses for the front of 96 WS6 and rear side markers in clear?
Thanks mike
Old Jun 12, 2003 | 02:38 PM
95_RipperZ's Avatar
I got brand new ones off ebay for $25. I think for the firebirds you have to make your own. check www.bfranker.badz28.com for instructions
Old Jun 12, 2003 | 04:53 PM
AW/whiteZ-28's Avatar
http://www.procarparts.com/store/dis...d=CBL-332-1679
I would suggest ebay first though
And they do not make rear clears for ta's anywhere you will have to make those yourself
They do have fronts though
http://www.procarparts.com/store/dis...DICL-XXFR-SM2X
Old Jun 12, 2003 | 05:39 PM
ishmuff's Avatar
I've got an extra set that is brand new that I got from procarparts.com that I will sale for $5 less than what I paid for them so that it would be worth your time. Let me know if any of you guys want them.
Old Jun 12, 2003 | 06:05 PM
Guys, I'm looking for clear corners that fit a 96 WS6 T/A. I looked on procarparts.com for t/a's and they fit 98-02
Old Jun 12, 2003 | 06:34 PM
ishmuff's Avatar
The one's I have fit the 93-97 Pontiac Firebirds and Trans Ams. Just let me know.
Old Jun 12, 2003 | 06:42 PM
How much ???
Old Jun 12, 2003 | 07:19 PM
*Ahem*
Originally posted by PROCARPARTS.COM
PONTIAC FIREBIRD 93-97 CLEAR FRONT BUMPER LIGHTS
SKU: CBL-332-1679
Description:
93-97 PONTIAC FIREBIRD CLEAR FRONT SIGNAL LIGHTS 2PC SET
EDIT: It doesn't even have a T/A listing on procarparts.com
BTW the firebird lenses are the same on your ta
Old Jun 13, 2003 | 12:43 PM
miller6t9's Avatar
would this be an example of lights to get off ebay?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2419177817
Old Jun 13, 2003 | 05:22 PM
Yea that's one example they have those and the regular clear's but there are only regular clears for firebird/T/A's the ones you posted are for camaro only
Old Jun 14, 2003 | 10:20 AM
TheV6Bird's Avatar
Yeah, here are my instructions:
CLEAR REAR SIDEMARKERS
  1. First, buy a clear plastic sheet of plastic from Home Depot. I don't know the name of the stuff, but it’s the stuff used in drop ceiling panels in offices. You will need a Dremel, or some rotary tool (variable speed ones are best, since a one speed, 35,000 RPM one will cut so fast it will melt the plastic that you must cut later) Also, buy some clear silicone and white spray paint (I used white engine enamel).
  2. Take the lenses off your car. You will then have to pry off the red lens from the housing. This is the toughest part of the whole project. Try heating it up with a hairdryer, and then try to pry it off gently with a flathead screwdriver. Don't worry if you crack the red lens plastic, because this stuff is VERY brittle. All you need is the gray housing anyway.
  3. Once you have separated the lenses, trace an outline of the housing on the plastic sheet (don't forget to trace the little stub the sticks out on one side). It was hard getting the pencil or marker to show on plastic, so I put down some masking tape on the plastic sheet, then traced with a marker. That allowed the lines to be shown on clear plastic. Always remember: it is better to be a little larger than a little smaller.
  4. Next, with the masking tape still on, you must cut out the plastic with a rotary tool. After cutting it out, test fit it to the housing. You may have to sand some rough edges with some sand paper or use the rotary tool if you have a sanding drum piece (like I did). You must also drill a hole where the screw will go to hold the lenses in place on the car. BE CAREFUL!! The plastic is very brittle, and I had my whole plastic lens crack off when I drilled the first time I did this.
  5. You should ask around on this step, since I don't know how many people have done it: Since the housing was a gray, and I wanted a white, smooth look for my white car, I painted the housing white with engine enamel (I used that because I thought the heat from the bulb would cause normal paint to flake or melt). Without it, the clear lens would show the gray part of the housing. So I put two coats of the white paint on the housing. If you don’t have a white car (say you own blue for example), you could buy some blue paint, paint the gray housing blue, then put the clear lens over it. That way, it would look blue when the light is off, but red when the light is on (rather than gray with the light off)
  6. Next you must silicone the clear lenses to the housing. This sounds simple, but it gets a little complicated. Since the stock red housing was thick, and the new clear lens was thin on my car, if I siliconed the clear lens to the housing with just one layer of silicone, the lens would sink in drastically from the car, making it look like a hole was in the car.
  7. I ran two thick layers of silicone down the edges of the housing (let the first one dry, put down second layer, attach lens, let dry) When the silicone dries, you may have to sand the edges so it will fit well. If you still see a small recession in the body because your silicone wasn't thick enough, then put some small blobs on the back of the housing to raise the ENTIRE housing up (rather than just the lens, which what you were doing before). This step is mostly trial and error.
  8. Also, remember that stub on the housing? Don't put silicone on that, it must fit in with the body. If you do get silicone on it, just use the rotary tool to saw it off. You will also need a red bulb so your lens will be street legal. The PN for the bulb is 194 for rear markers (If I remember correctly) I used the APC ones from Pep Boys, and they are fine to me and have not blown out. However, the red bulb gives off a “pink” tint when illuminated. That didn’t bother me, but if it bothers you, I am sure there must be some way to hook up a red LED bulb to give the real “red” look.
Good luck with this process, if you have any questions, e-mail me.
Old Jun 14, 2003 | 01:25 PM
ishmuff's Avatar
How much ???
$50 shipped
Novo
Jun 14, 2016 02:58 AM
PopoFormula
Oct 12, 2015 04:19 PM
HAWG
Sep 25, 2015 11:41 AM
tommalcolm
Sep 11, 2015 03:39 PM
