what to use to hold up my ground effects
Old May 7, 2003 | 04:24 PM
whataretheodds's Avatar
i have the slp ground effect in the rear for the center exhaust..is there anytype of glue that i can use to hlod this piece on? i have been using 3 m tape and it doesn't hold up for a long time...any suggestions of what else i can use..thanks
Old May 7, 2003 | 10:08 PM
abba_zaba's Avatar
http://www21.3m.com/dr/v2/ec_main.en...P=0&CACHE_ID=0
you will find what you need there. automotive paint suppliers usually carry a good selection of adhesives. you could probably ask someone who works there which they recommend.
Old May 8, 2003 | 11:38 AM
Pewter 2kFormula's Avatar
The guy that installed my WW gfx used epoxy on mine. They applied the epoxy then screwed on the pieces. Once it was set/dry they took the screws out and covered the holes up.
LT14LIFE
Nov 15, 2015 06:22 PM
Greg88
Sep 20, 2015 07:14 PM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
92_RS_305
Sep 8, 2015 07:47 PM
