what size tires?
Old Jun 19, 2003 | 11:19 PM
hazard2k's Avatar
what size tires?
I was looking at these rims http://wheelsforless.com/search_resu...ct_ID=ea779-88 (the ones at the bottom) and was wondering what size tires i could get to go with them. I was hoping i could get some 275/35/18's on all fours. Will these tires fit on those rims without any problems? If they do will i have any rubbing/brake problems with the front or the rear? I think the rear will be fine but the front is what im mainly worried about when turning. If they will rub in the front, whats the biggest size i can get that i wont have any problems? thanks a lot
Old Jun 19, 2003 | 11:26 PM
TA25th's Avatar
You can't safely run a 275 on an 8 inch wide rim. MAX I would go would be a 245
-Shawn
Old Jun 20, 2003 | 07:25 AM
94BlackBowtie's Avatar
First of all - if you decide to get these wheels - don't buy them from there - look on e-bay or cruise over to www.eaglewheels.com ...
Second of all, the MAX you should really even possibly maybe consider putting on there is a 255 - but, it's like TA25th said, a 245 is what you want to go with (245/40's)...
The fact that it is 18" makes a difference too.
I just got educated on this real good a few days ago, check out the thread if you like.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
LD Kirk
Apr 30, 2015 08:54 AM
shroyvin56
Apr 3, 2015 08:15 AM
cristian1311
Mar 4, 2015 04:45 PM
