What are my T/A headlight options???
Old Sep 18, 2003 | 04:02 AM
96 WS6's Avatar
What can I get that will make them better/brighter???
Old Sep 18, 2003 | 07:15 AM
94BlackBowtie's Avatar
Your best bet -
Sylvania makes Silverstars for your application, so you are in luck.
Sylvania PN#: H4666ST. This is the most expensive of the Sylvania upgrades - but is still cheaper than your other options, that are gonna be hard to match to this.
Second option would be the Sylvania XtraVision Upgrade.
Part #: H4666XV. They are "Three times brighter & twice the life of standard."
Third option - cool blue's from Sylvania. I think they look cheap, but its an option. Part #: H4666CB.
The Silverstars are going to look best, and give you the most output. You should be able to get these at your local parts store - Advance Auto Parts runs specials on the Silverstar stuff quite often.
You can also get some 165mm Rectangular housings, and run H4 bulbs in them. Check out this site for some more info. (See note underneath the yellow section with the 165mm's listed).
That should get you started anyhow.
Ks0209
Oct 1, 2015 07:32 AM
CARiD
Sep 30, 2015 05:44 AM
Bxlt1
Sep 29, 2015 03:18 PM
