What is the Firebird front bumper made out of?
Old Sep 28, 2006 | 02:40 PM
Camarocracy's Avatar
Is it plastic or fiberglass? I have a small dent on the nose right above the opening by the front plate. It's right on the edge as it curves down. I know I didn't lean on it or anything, I wonder how it came there
Old Sep 28, 2006 | 02:57 PM
oneslowz28's Avatar
Re: What is the Firebird front bumper made out of?
its made of a polyurathane / glass mixture called smc (speciality molded compound) If you glass over it expect it to crack in a few weeks. The only way to fix it and not worry about the it cracking is to replace it entirely. Replacements can be found for around 200 bucks online. some people have stated they used a hea gun to remove dents but i dont sujest using this method
Old Sep 28, 2006 | 06:14 PM
jerry caesar's Avatar
not smc, thermoplastic. SMC (sheet molded compound) doesnt bend and is what the doors are made of..
try to find some info on plastic repair, try here http://www.automotivereconditioning.com/
or google plastic repair
If you remove the bumper, look for some indentions that resemble >PUR< or >RIM< , these are thermosets, im not sure if you can heat these materials without ruining the bumper even more. I'll reply back in a few minutes after I look some things up.
Old Sep 28, 2006 | 06:57 PM
LastZ4ME's Avatar
Bumpers are plastic
Doors/Hatch are SMC
Fenders are R.I.M. (reaction injected molded) Plastic.
Quarters are steel.
Roof Skin?? I think its SMC also
Old Sep 29, 2006 | 02:31 AM
oneslowz28's Avatar
sorry for the bad info.
Old Sep 29, 2006 | 08:32 AM
kick Z tail out's Avatar
Sugar and spice
Old Sep 30, 2006 | 11:29 PM
SVTNTMR's Avatar
Not to be rude but....everything you said was wrong.
The bumper cover is made from TPO, and SMC stands for Sheet moulding compound. And depending on the type of dent ect. a heat gun might do the trick although I wouldnt recomend it for someone with no experience.
I have repaired several minor imperfections in bumper covers with a heat gun.
The heat gun softens and relaxes the bumper and allows you to massage it back into shape, larger repairs generally require a repaint. there is also several different types of semi regid repair/fillers on the market that work great and will last the life of the cover if used correctly. Unless its a large erea or its torn on an edge that is stressed the cover can be usually be repaired.
Jun 6, 2015 08:27 AM
QuickSilver02
Apr 7, 2015 11:12 AM
CARiD
Feb 9, 2015 09:35 AM
Jazsun
Dec 29, 2014 12:14 PM
