What besides 3M can i use?
Old Sep 26, 2006 | 08:19 AM
chasmanz28's Avatar
I have a solar window wing for my camaro that i must have installed 4 times already, and at the ends of both sides the tape always fails, can i use anything else to solve this problem
Old Sep 26, 2006 | 09:38 AM
CrazyJim's Avatar
Member
Re: What besides 3M can i use?
Originally Posted by chasmanz28
I have a solar wing for my camaro that i must have installed 4 times already, and at the ends of both sides the tape always fails, can i use anything else to solve this problem
A solar wing? Does it recharge your battery?
Old Sep 26, 2006 | 02:14 PM
chasmanz28's Avatar
lol your funny.
Old Sep 26, 2006 | 02:26 PM
JakeRobb's Avatar
Super Moderator
lol your funny.
His funny what?
I don't know what a solar wing is either. Is it a spoiler? And you're just taping it on? Spoilers need to be screwed / bolted on.
That said, the following spoilers are approved for use on 4th gen Camaros (and this is a complete and final list):
1. Stock V6/Z28 spoiler
2. Above w/ factory ground effects package extension
3. SS spoiler
4. One of those really long drag racing spoilers, but only if it's a drag-only car.
Aftermarket replicas of the factory spoilers are acceptable.
Old Sep 26, 2006 | 03:48 PM
chasmanz28's Avatar
Originally Posted by JakeRobb
His funny what?
3. SS spoiler
it goes on the glass in back of the hatch above the trim, i thought everyone knew about this my bad, you have to use tape, thats what came with it but if fails all the time, i guessing the wind weakens the joint after time. Copy and paste for a picture of what it looks like. Hhttp://www.lmperformance.com/2391/1
Old Sep 26, 2006 | 08:17 PM
igobuk's Avatar
Clean off the glass and clean off the wing. Then use some clear RTV silicone on the wing. Rub it on the wing so that you have a nice thin coating. Then place it on the hatch carefully and gently push down on the wing section by section to squeeze any air from in between the hatch and the wing. Be very careful not to cause the wing to slide when doing this because things will get messy.
The wing will be on very, very securely and if you ever want to take it off, it will peel off with a razor and leave no residue behind.
I used this method to stick on "eyebrows", headlight and tail light covers and none have ever flown off.
Should work for you too.
Old Sep 26, 2006 | 09:01 PM
igobuk's Avatar
Originally Posted by BIGKerneL44
use the stuff to cement the rear view mirrors to the windshield glass. It is meant to bond with glass.
This glue, when dry, is brittle and because the wing is flexible, it will crack off. Also, this glue is pretty strong and may fog up the acrylic if not ruin it. It is not meant for plastic.
Old Sep 26, 2006 | 09:16 PM
gt_biker13's Avatar
Its a sign. God doesn't like solar wings
shock6906's Avatar
Amen.
Old Sep 26, 2006 | 09:54 PM
razor02097's Avatar
it looks like a BB hat bill...
Old Sep 27, 2006 | 10:34 AM
TheV6Bird's Avatar
If nothing works, just contact 3M directly. Try to get one of their super strong industrial adhesive if their consumer automotive adhesives isn't working.
Old Sep 27, 2006 | 01:51 PM
chasmanz28's Avatar
hmm, dunno what kind you got then b/c i had a solar wing on my camaro for about 2 years and it was applied with that kind of glue. realized i didnt liek the wing when i got out of HS, removed it with a razor, no damage
maybe ill try what you did, just dont know where i can pick up a large amount of that stuff
