weather stripping
Old Oct 13, 2002 | 04:04 PM
nothingeined's Avatar
weather stripping
is it easy to change the weather stripping on the door seal. my driver's side has a teat and when i close the window, the window has a minor space so it leaks. is there a way to fix it with thicker or can i just change it? thanks
Old Oct 14, 2002 | 11:46 PM
fbird95's Avatar
Depending on how big the gap is, the window and or the t-top needs to be adjsuted. If your talking about the top weather stripping where the window meets the t-top it is easy to replace but it may not solve the problem, adjust is most likely required.
Old Oct 17, 2002 | 01:44 AM
Mellowdork's Avatar
Okay i got a leak too here. How you do adjust the T top? Is there like a screw somewhere or something? what do we do?
freddy
Old Oct 17, 2002 | 04:57 PM
fbird95's Avatar
First take out the t-tops. then you will see two screws on the font peice that the tops look into take them out and pop the peice off. Do the same on the back. Once these are removed the adjustment is self explainitory. The back may be a little more tricky becuase the headliner may have to held out of the way during adjustment. This usually happens more often than not on the pasenger's side.
Old Oct 17, 2002 | 08:15 PM
Crutt82's Avatar
i just discovered a puddle of water on my passenger side floor. I'm not sure where the water is coming from. Is it coming from through the door weather stripping? Is there a way to find out?
Old Oct 17, 2002 | 08:54 PM
do what i did and sit in the passenger side and just look up. you will be able to tell or at least i did.
Old Oct 18, 2002 | 12:06 AM
Mellowdork's Avatar
I went through a car wash. haha. I found out where the leak was quick.
Old Oct 18, 2002 | 11:28 AM
fbird95's Avatar
The large amount of water behind the pasenger seat in my car was a result of water running behind the weather stripping that GM does not glue down. Take off the trim and caulk the stripping to the car. solves the problem right away. Check the rear hatch too.
Old Oct 18, 2002 | 05:38 PM
Crutt82's Avatar
But I was in the car on the day that it rained and i didn't see it dripping from the ceiling anywhere and nothing else is wet, just the pass. side front floor.
Old Oct 20, 2002 | 01:45 PM
Crutt82's Avatar
and another thing.
theres a gap between the weather stripping and the window.
the weather stripping seems to be in good shape.
What causes this and is there anything i can do about it?
Old Oct 20, 2002 | 07:14 PM
okay i found some little info on my problem, so i hope it would help other people. i found out that may was once totaled, (thanks carfax! ) hence the small gap between the door. so some body guy told me that he would replace my weather stripping with a thicker one and it would fill in my gap. 50 bucks aint bad compared to a whole right side door that my chevy dealership quoted me. Ill find on friday if it does.
Old Oct 26, 2002 | 08:36 AM
Crutt82's Avatar
Did changing the weather stripping help?
Old Oct 26, 2002 | 10:44 AM
Okay i just got my car back and changing out the the weather stripping fixed my problem. looks brand new so i hope it works as good for everybody else out there with the same problem.
Old Nov 3, 2002 | 09:04 AM
96Z28man's Avatar
Who sells weather stipping for my 96 Z?? I have real bad leaks
Old Nov 3, 2002 | 11:45 AM
unfortunenatley i had to order mine from the dealership. i did not have a chance to check around at autozone or anything like that. they might have it there but if not, the dealership
