VFN Pin on hood?
Old Sep 4, 2002 | 09:00 PM
Red_94Formula's Avatar
Question VFN Pin on hood?
VFN has a stock mold of Firebird hood that weighs only 11 pounds!!! 32 pounds less then stock!!! only thing is it is a pin on hood.
Has anyone ever used a pin on hood? does anyone know anything about installing one?
i guess it doesnt use hinges at all so are there 4 pins, one at each corner holding it in place?
Here is there web site for anyone who needs it. http://www.vfnfiberglass.com/
any help would be great. even a pic.
Red 1994 Formula (V8,M6,3.23)
K&N fipk,MSD coil,Hooker Exaust,SLP 1 3/4 headers,LT4 KM,CAM 220/229 .547/.544 112LS,Taylor Wires OVC,160°T-Stat,LT1 Edit,ZR1 rims 315's,EGR!,AIR!,Meziere H2O Pump,3"Cut Out,Power slot rotors,Earl's Brake Lines,Mac Girdle,!CAT,M6 Conversion,SCR SFCs,!MAF,MAC LCAs,Kirban Shifter,!ALT,200 Amp Alt,7/16's 1.5RRs,NGK TR55's,SLP STB,Polyurethane bushings everywhere,SLP Bilstiens,Susp Tech springs #63045,LS1 DS,SLP flywheel,RPS clutch, PA K-member,
Best 1/4 13.47@103.87 (no where near current)
Installing:3.73's,Auburn Posi,MS PA control arms, Trans Am body
Old Sep 5, 2002 | 06:23 AM
RacinLT1's Avatar
Post
I dont have a Pin on hood for this car.Idid have 1 on an old truck and made working on it great. Hardest part is getting the mounting points for the pins,to make sure the hood is secure at speed. You can use DZUS clips,but that will add cost to the install.
Dirk
1997 TA A4
11.251@119.3 1.52 60',7.132@95.39 1/8
The RacinLT1
RacinLT1 pic's
Novo
Jun 14, 2016 02:58 AM
Stephen68
Oct 16, 2015 03:50 PM
CARiD
Sep 30, 2015 05:44 AM
gearhead3
Parts Wanted
Sep 16, 2015 08:18 AM
Daluchman1974
Sep 11, 2015 06:12 AM
