Trans am light shaking....???
Old Nov 15, 2004 | 09:35 PM
jare23's Avatar
i have a 95 TA, it has a bad front bearing that i know i need to replace but just a small part of the problem i think.the headlights shake on bumps and high speeds on the highway. you can't physically see the light assembly itself bouncing but the beam is noticeable. any ideas on what this could be?
Old Nov 16, 2004 | 11:39 AM
firehawkformula's Avatar
Re: Trans am light shaking....???
I had that problem with my 95 formula , the problem was that the rivit to the headlight pannel that holds the headlight support cable (when the light is up) was loose, I fixxed it by taking out the screw that holds the cable to the light assembly and put in a bunch of washers (4) to take up the slack
Its kinda of tight working quaters and sort of teadious but its alot better than having shaking headlights, also youll prolly have to reaim your headlights after your done
Old Nov 16, 2004 | 05:27 PM
jare23's Avatar
are u referring to the steel braded cable underneath the entire assembly? thats the only one i can see to be loose or close to what you describe.
Old Nov 16, 2004 | 07:46 PM
thats it
Old Nov 16, 2004 | 09:49 PM
jare23's Avatar
thanks for the help. i just got one done but the other will have to wait til tomo. i hope the right side will use less washers. my left side needed around 9-10!!! scared me. oh well. problem fixed for now. on to the next of things to do.thanks again.
Old Nov 17, 2004 | 10:38 AM
Myxtreme1's Avatar
YEah I need to write this down~I hate the shaking headlights!
Old Nov 17, 2004 | 11:22 AM
BigEvil's Avatar
Yeah, I'm gonna have to check that out myself. I've noticed the same thing, and wasn't sure how to go about fixing it. Thanks!
Old Nov 17, 2004 | 11:40 AM
no problem guys, instead of washers you could use a bushing or nut to take up space
Old Nov 17, 2004 | 12:42 PM
jare23's Avatar
id just be careful on using to big of nut or washer to fill the space. when i did mine i used a washer that was too big and my light housing wouldnt even fit back on. but like he said you will have to recalibrate the beam. my left one is almost 4ft to the left of center.....
RUENUF
Mar 13, 2016 03:39 PM
Brake_L8
Jan 20, 2015 09:44 AM
Jan 5, 2015 07:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
