thinking about making my own projector HIDs
Old May 11, 2005 | 08:50 PM
RedDemonZ's Avatar
I am seriously considering grafting some projectors into a stock headlight housing (for the low beam), and running HIDs for both the high and low beams.
My logic on this is that the projector will focus the light for normal driving and the refractor lens will scatter the HID light for super bright high beams...
Here are the projectors i am thinking of using. If not these, something very similar, most likely from a lexus. (I want something small that i can mount to the back of the housing with the black projector part in the actual housing....)
Please post any thoughts or comments that you think might help or I might need to consider before starting this project.
Old May 11, 2005 | 09:43 PM
pu12en12g's Avatar
Re: thinking about making my own projector HIDs
http://web.camaross.com/forums/showthread.php?t=62272
Old May 11, 2005 | 09:45 PM
RedDemonZ's Avatar
ive got a 2002
Old May 12, 2005 | 03:16 PM
iansane's Avatar
The Hella lights that that link referred to are probably easier to mount up than the lexus ones. I've got the Hella's mounted in the bumper of my 91 bird and I love the light output. The only reason I say it'd be easier is because the mounting points are real uniform around the outside of the projector housing. Either way you'll be chopping up the stock housing for fit projectors in. Do it.
Old May 12, 2005 | 04:04 PM
Wraith's Avatar
Wink Re: thinking about making my own projector HIDs
ive got a 2002
You don't need HID for the high beams. Already been done using Hella 90mm projectors
http://community.webshots.com/album/116863233uyEamc
Old May 12, 2005 | 05:05 PM
RedDemonZ's Avatar
well damn. I always thought those were just halogen projectors. Thanks for the idea.
Old May 12, 2005 | 09:45 PM
pu12en12g's Avatar
I can't believe you have the Autooptiks listed in that lighting guide in your sig. The owner of Autooptiks should get beat the **** down IMO.
Old May 13, 2005 | 04:27 PM
Wraith's Avatar
Considering I made that "guide" back in 1998 and got locked out of it by Homestead, I can't change it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
warmeck
Feb 5, 2015 11:04 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
