Tailight's fill up like fishtank..
Old Jul 1, 2009 | 07:23 AM
derrickgott007's Avatar
Do ya'll ever suffer from this? When it rains my tail lights fill like fishtanks! I had one so full that it was way over the bulbs, and they still worked!!! Lol.
I ended up drilling a few small holes in the corner of the lense to let the water drain out as I have replaced the bulbs about 5 times due to this...
Where exactly do they leak in at?
Old Jul 1, 2009 | 11:20 AM
Brangeta's Avatar
I've never had that happen, that's weird.
Old Jul 1, 2009 | 11:23 AM
Z28SORR's Avatar
Usually at the top there the "lens" and the "reflector" mate. They usually seperate at the mating line along the top. You can use some clear RTV or some kind of epoxy clue to reseal them.
Old Jul 1, 2009 | 08:08 PM
johnny6's Avatar
You should throw a couple of goldfish in each tail light and snap some pics Seriously though it sounds like your lens are seperating just like ^ he said.
Old Jul 1, 2009 | 10:17 PM
1995blackttopta's Avatar
is it bad that i was going to come in here and post the same thing?
Old Jul 3, 2009 | 08:39 PM
n2ceptor's Avatar
Permatex® Clear RTV Silicone Adhesive Sealant
http://www.permatex.com/products/Aut...ve_Sealant.htm
The lens is separating from housing... Just needs to be sealed...
Old Jul 4, 2009 | 05:47 PM
Chevyssoccer's Avatar
Ive had the drivers side happen twice. Before the 2nd time i completely resealed the whole thing with silicon. It sucks because the water takes off the chrome reflective finish.
Old Jul 7, 2009 | 01:35 AM
SmokeyBlaZe's Avatar
I had this same problem about a week ago. It was where the lens meets the reflector at the top , all I did was drill a small hole in the bottom of the housing with the taillight out and if you notice when the light is out there is a place under the tail light with a groove. I marked this spot to drill the hole so it would have room to drain out. Easy Fix but still had a couple bulbs to replace.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
Pwilson59
Sep 3, 2015 08:47 PM
alphaauto
Jul 26, 2015 04:40 PM
Boss002
Jul 9, 2015 03:33 PM
