TA door panels and relocated switches.
I recently did the TA door panel swap on my '01 Z28. They look so much better. Then I came up with the idea to relocate the switches. So I decided to put a set of Camaro windows switches in the radio bezel inbetween the ASR and fog light switches. The only problem is the little window symbol is sideways. If anyone has a suggestion on how to fix that. Also I had already filled in the ashtray in the consol so decided I didn't need the lighter, so I enlarged the hole and put the TA mirror switch there. I relocated all the wiring and rewired for the TA mirror switch, so everything works thus far. The only thing I have left to work out is the door lock switch.
Here are a couple pictures. What do you think? |
Re: TA door panels and relocated switches.
thats real slick , i was thinking about doing something like that ...........it gives the door panels a nice smooth look .
kev |
Is there anyway to pop off the window/door lock switches from the panels on a 1994 Camaro? I want to put the switches somewhere slick looking, but without dealing with that panel (it would cause clearance issues, i'm sure) Also, how would you run the wires? just cut and splice in longer wire to extend it?
how tough was it to fit the TA door panels in place of the stock Z ones? I know a lot of people have done it and i think it looks excellent.
What is the benefit of the TA Switches? What i want to do is pull the switches out of the doors, take off the little surrounding panels they are on...then use those same switches and put in a new piece of plastic where the cigarette lighter is (i don't need the cigarette lighter anyway, and if i really need it, i can re-mount it elsewhere) and just mount the door lock button (single switch instead of dual) and then mount the two window switches right below the door lock switch, vertically (like they are on the doors) and try to mount the side mirror adjusting switch somewhere on the dash near the steering wheel. What i want to do after that is somehow fill in the gap on the door where the switch panel is currently...does anyone have any ideas what to fill it with? Body filler obviously won't work...but is there anything i could put in there that will make it look smooth and clean, as if it was stock? i plan on painting the doors anyway (i'm painting the doors black, with green vinyl over the cloth.) I'm hoping i can do it the way i want it, cause i think it would give it a very nice look for both the doors and the center console...
Any help is appreciated! Thanks in advance. Nick |
There is no benifit to using the TA switches over the Camaro. Just preference. What I did to fill was epoxy a piece of plastic on the back side of the hole and then bondo to level everything out. Then I primed and painted.
I made my own hole for the mirror switch and used a dremel to modify the holes in the console for the window switches. You could do the same thing and maybe epoxy the switches to the console? |
The mirrors need to be rewired for the TA swtich and an extra wire run to the passenger side. I have a diagram somewhere on how they need to be wired. |
Sounds like a great idea...but i thought bondo was for fiberglass? Maybe i'll go pick some up tomorrow morning and get started...i hope it works...i painted my interior yesterday and the switches have been acting up, maybe some paint got in the plugs, let's just hope the wires are all okay...
Wow, that looks amazing. What a great idea!
