Step inside to see the difference HID's can do...
Old Apr 22, 2008 | 09:42 PM
CALL911's Avatar
I recently bought some HID's for my 95 Z28 in my sig off of ebay. My particular kit came with the HID bulbs (5000k color/temp), the ballasts, and new housings (stock looking) to put the bulbs through.
Here are some before and after pics for those wondering what the difference is.
All pictures were left in their original raw form (no photoshopping done), and pictures were taken in the exact same spots before and after at the same time of night (not any different lighting other than from the car).
Before (factory Halogens)
After (HID's)
Before
After (minus the empty bags of conrete mix I cleaned up)
Before
After
Old Apr 22, 2008 | 10:57 PM
lt1 beast's Avatar
great looking pics and im amazed with your headlights. I am interested in doing this myself. would it be too much to ask for a write up when you have the time?
Old Apr 23, 2008 | 05:51 AM
CALL911's Avatar
Yeah, I can do a write up, but the kit was really straight forward to install (I think pretty much all of them are), since they are pretty much a plug and play setup. My kit didn't even come with any install instructions, and although I initially had trouble as I had some connecters on backwards, the overall install was fairly simple.
I know some guys have used their stock housings, and just heated the back of them to get the bulbs out and then RTV'd the new HID's in. My kit came with new housings that sealed the bulbs in.
LEDgauges.com has them for like $350 (with new headlight housings). Mine came with everything that the kit from LEDgauges came with but spent half as much. There are other ones out there that you don't get new housings with that would be much less than I even spent, but having sealed housings you don't have to goop on RTV to is the better way IMO.
Old Apr 24, 2008 | 02:16 AM
Brangeta's Avatar
I see whatcha did buddy... you just aimed them up and turned on the highbeams!
Just kidding! Looks great!
Old Apr 27, 2008 | 06:43 AM
Future_Z_Owner's Avatar
Hah. Looks like someone else lost faith in Focuz Tech's little venture.
*Triumph The Insult Comic Dog Voice*
I keed i keed!
Looks good. Id love to see the write up.
Old Apr 27, 2008 | 10:31 AM
CALL911's Avatar
I keed i keed!
This actually has nothing to do with FocuzTech's headlamp project. The new headlamps they will be making will have HID's as an option. I figured if I already had the ballasts and the bulbs waiting for the new headlamps I would already have a good start when they become available.
Old Apr 27, 2008 | 11:08 AM
96SilverRam's Avatar
Good job, you will need good lighting in Fort Wayne considering how many damn potholes are everywhere after a northern winter
HID's definitely produce more visible light, but the beam pattern in a stock housing is just whack. I've done the HID's for my main lighting and foglights, I just wish someone would make a true projector housing that is plug and play (and not cost $1000 for the pair of projectors).
Old Apr 27, 2008 | 02:06 PM
CALL911's Avatar
True, there are no true "plug and play" projector HID kits out there yet. FocuzTech's should be the first one when they do come out. But even then you have to consider that most plain HID kits just on their own with just the ballasts and bulbs cost on average $250+. Now add something like a Hella projector, and then some kind of plug and play housing to go in on top of all that and you definatly won't have an inexpensive kit.
It's just like any other performance mod really. You gotta pay to play!
Old Apr 27, 2008 | 02:19 PM
Zepher's Avatar
your exposure times were different for your images.
the HID pictures were longer exposures.
Old Apr 27, 2008 | 02:35 PM
CALL911's Avatar
I love how people like you just pop in here and tell me what I did.
"No" you are incorrect. The pictures were taken on my Canon Rebel XTi, and the aperture, and ISO (imaging sensor's sensitivity to light) settings were documented from the first Halogen pictures. I then made sure the identical settings were used for the HID after pictures. The photographs were taken at the same time of night, in the same exact spots (within a few feet), and no photoshopping was done.
I did this all because I wanted to show the "true difference", and not a skewed truth by changing different camera settings or photoshopping.
Old Apr 27, 2008 | 03:01 PM
Zepher's Avatar
Halogen Image:
Exposure Time = 1/2"
F Number = F3.5
Exposure Program = Not defined
ISO Speed Ratings = 400
Exif Version = Version 2.21
Date Time Original = 2008-04-16 22:16:13
Date Time Digitized = 2008-04-16 22:16:13
Components Configuration = YCbcr
Shutter Speed Value = 1 TV
Aperture Value = 3.61 AV
Exposure Bias Value = ±0EV
Metering Mode = Pattern
Flash = Flash did not fire, compulsory flash mode
Focal Length = 18mm
Maker Note = 4876 Byte
HID:
Exposure Time = 1/1"
F Number = F3.5
Date Time Original = 2008-04-22 22:00:11
Date Time Digitized = 2008-04-22 22:00:11
Shutter Speed Value = 0 TV
Focal Length = 18mm
Old Apr 28, 2008 | 05:22 AM
CALL911's Avatar
Nope.
Old Apr 28, 2008 | 07:52 AM
Zepher's Avatar
Originally Posted by CALL911
Nope.
Nope what? I can clearly see that you used a .5 sec shutter on the Halogen Photo and a 1 sec shutter speed on the HID Photo.
These are the last 2 images.
Old Apr 30, 2008 | 09:12 PM
CALL911's Avatar
I'm not going to waste my thread on arguing with you Zepher.
Old May 1, 2008 | 07:18 PM
Sinister/Rocinrol's Avatar
I just installed the true HID Projectors in my car and there really is a difference big time!
Low Beams
High Beams
