Steering wheel adapter for '95 Column
I have a column from a '95 Z in my '48 Chevy street rod. I want to put an aftermarket steering wheel on and the sellers (flaming river and grant) I've talked to don't want to help because the donor car was airbag-equipped. Does anyone know if the center shaft with the splines are the same as a pre-1990 column? I may just order one and see if it fits but hoping to avoid the hassle if it doesn't.
Thanks in advance, Walt |
Re: Steering wheel adapter for '95 Column
I put a Grant wheel on my 94 Formula. I used the Grant install kit for a 3rd Gen Camaro.
I may have the kit part # somewhere in my garage. https://cimg7.ibsrv.net/gimg/www.cam...2e612d1c8.jpeg |
I figured the splined shaft was probably the same. I measured the column in my '39 street rod and the circumference at the top was the same as my Z column. I'll call grant and tell them I want the install kit for an 88 Camaro. As always, thanks for the help. BTW, here is the cowl painted on my 48 Z28. Rest will be painted soon.
https://cimg2.ibsrv.net/gimg/www.cam...6906972c42.jpg |
Google AI…… for the kit I used:
Yes, the Grant 3196 steering wheel installation kit is designed to fit a 1988 Camaro . This kit is compatible with a range of GM vehicles from 1969 to 1994, including the 1988 Camaro, and includes the necessary die-cast hub and hardware for installation.
| All times are GMT -5. The time now is 12:17 AM. |
