ss trunk
ss trunk
hi. my mom has a 94 Z28. im thinking about adding an SS spoiler to it and i was wondering if the spoiler is attached to the trunk hatch itself. if so, will it flow evenly with the curves of a Z28?
thanks
Matt
thanks
Matt
Re: ss trunk
Yes and yes
Bunch of pictures here showing how it attaches...
http://www.bfranker.badz28.com/fbody/ssrepaint.htm
Good pic here showing the bolts in the spoiler...
http://www.bfranker.badz28.com/fbody/ss1736.JPG
and you can see where it fits through the hatch here...
http://www.bfranker.badz28.com/fbody/ss1707.JPG
Re: ss trunk
thanks for the info, and that car looks awasome. will the trunk from a 2002 SS fit and match the lines also? i think im looking for the one with the 2 pillers under the spoiler. thanks for the help
matt
matt
Re: ss trunk
matt
matt
Re: ss trunk
Yes. The rear end of the 4th Gen Camaro never changed from 1993-2002. The tail lights changed color in 1997 (they are a direct fit for any 4th Gen Camaro too). So, the SS spoiler will bolt on to any 4th Gen Camaro, and will look factory. This is a super easy mod, and can be accomplished in about 10 minutes.
Re: ss trunk
and you have to rewire it to accept the led 3rd brake light(i.e. resistors, etc.)
it does bolt on but getting the original to unbolt takes forever
and the middle 2 "fangs" just hold on by 3m double sided tape
Re: ss trunk
Originally Posted by georgiaz28
total BS........10 mins my ****.....more like 2-3 hours
Yes, wiring will take longer, but the fact that you can have the spoiler swapped in minutes is true.
Re: ss trunk
Originally Posted by Taintedz28
^^ do what? whos crack ahve you been smoking? We've switched one from a ****ing 93 z28 to an 01 z28 and it fit together fine, took all of 15 mins...
i know from personal experience
when i pulled mine off there was some hardcore glue/adhesive holding it on to the hatch and it took forever cause i didn't want to crack the paint and just rip it off
aren't all the wings held on by this adhesive crap
mine sure was and it sucked
Re: ss trunk
Even if you didn't want to "crack the paint" a little fishing string would have made quick work of the adhesive (3M tape) holding the pedestals on...
You learn each time though... the first time I did and Opti it was like 9 hours
Re: ss trunk
Love the car Brent! I would change the door handles out to black. The current color handles make the car look like it has a cheap paint job and they just painted over everything. I know that the paint work is top notch, but just if someone was looking at your car and didnt see your write-up thats what most people think. Other than that I think its great! Also some smoked turn signals would look awesome.
