SHift knob options??
Old Jan 18, 2008 | 05:51 PM
Bayer-Z28's Avatar
SHift **** options??
Any other shift **** options besides these?
I have this one..
Does not like..
Also does not like..
Old Jan 18, 2008 | 08:44 PM
Bud M's Avatar
I have a Momo **** on my Pro 5.0. Took a little bit of clearancing inside the hole to fit onto the stick, not much, took just a few minutes with an air grinder.
Old Jan 19, 2008 | 09:22 AM
96 Z 28's Avatar
Bayer:
Do you have anything besides the ****?? (Heehee I said ****)
I've got SLP's Shifter Base, the same ****, and Lou's Short Stick
With all of that the shifting feels entirely different, precise, and quick.
SLP doesn't seem to sell the Shifter Base anymore, but here's a package from AfterMarketAuto.com Pro 5.0 Package that would be similar
Old Jan 19, 2008 | 10:22 AM
CALL911's Avatar
Check out http://www.ripps70.com/Page_1.html
They have a ton of different options, and can even make you a custom one like they did for me
Old Jan 19, 2008 | 11:57 AM
The SRZ's Avatar
Mine here. Custom made marble. Can't remember the name off hand though. Still a trade secret.
Old Jan 19, 2008 | 03:12 PM
Greed4Speed's Avatar
Those look nice, but do they get hot in the summer? I had afriend that had an hard plastic one and it would get hotter than I care to touch after the car sat out in the summer.
On the short stick 5.0 combo, I wouldn't spend the extra cash. All you have to do is litereally cut .25" off the top of the shifter stick supplied by Pro 5.0 and you have a short stick. Don't worry, the stick is threaded further down than needed. There now you have $30-40 extra that you didn't spend on a Lou's stick to put towards a ****.
Old Jan 19, 2008 | 03:36 PM
96 Z 28's Avatar
On the Lou's Stick issue, you CAN just cust the stocker, except that it has a Jog in it, and IMHO that puts the Shifter slightly out of place when cut
So if $50 is an issue go for the chop, but I would stand behind Lou and the Short Stick
Old Jan 19, 2008 | 04:18 PM
CALL911's Avatar
Nothing will get much cooler than marble or plastic in the heat of the summer (maybe rubber, but it'll still be hot). They really aren't bad IMO, especially compared to a metal shift ****. I have one of those in my Formula, and it will give you frostbite in the winter, and burn you in the summer.
Old Jan 19, 2008 | 04:28 PM
Ponykillr's Avatar
http://www.autoartmodels.com/pages/aadesign/index.htm Go to page 6
Old Jan 19, 2008 | 08:24 PM
W/the pro 5.0 you don't use the stock stick. The stick provided w/the pro 5.0 is a solid piece of metal just like the Lou's. It just comes longer so you can cut it to your desired length.
I had an aftermarket short stick on my stock Hurst. When I bought to the pro 5.0, it was used and the stick had already been cut and was the same length as the aftermarket short stick I had.
Old Jan 19, 2008 | 09:37 PM
96 Z 28's Avatar
Ahhhhhh Sounds like then you could skip Lou's Short stick if you go wiith the Pro 5.0 Shifter as long as you shorten the stick yourself
Old Jan 19, 2008 | 09:43 PM
ReNxWar's Avatar
I went with a C6 shift ****. It was in the 80$s if I remember right, but definitely looks kick ***.
MyfateZ28
Oct 5, 2015 12:36 PM
willismoons
May 27, 2015 04:03 PM
PROJECT X
Apr 17, 2015 12:13 AM
Apr 16, 2015 09:57 AM
Jason Short
Jan 19, 2015 06:34 PM
