shaved antenna?
Old Oct 10, 2003 | 05:10 PM
1994TransAm's Avatar
shaved antenna?
hey guys,
i'm getting the car ready for monday, its going to the paint shop where i'm gonna seal and paint my car, i broke the antenna trying to take it out so i bought a hidden antenna kit on ebay and i'm shaving the antenna's old hole.
how do i do this?
i was thinking, cutting a peice of metal and then glueing it on the backside of the quarter and filling the hole with bondo, prime, block sand and paint!!!!!
what do you think.
Old Oct 10, 2003 | 05:51 PM
kingman109's Avatar
again not expert... but u need to cut the hole... cut a matching piece of metal and form it to fit the curve if any...then u need to go around tack welding it untill u have a solid bead... grind it smooth...sand.... primer...and paint...
i guess
Old Oct 10, 2003 | 06:17 PM
stang_killa94's Avatar
cut a piece of metal the same shape and size then use a countour gauge to get the exact contour of the body then bend the piece of metal to that shape and then tac weld all the way around til the circle is completed then grind the welds smooth and then do all the body work.
Old Oct 10, 2003 | 07:40 PM
Z95m6's Avatar
you could just weld a crude patch on the under side then take a hole saw and cut a perfect hole. Then take your hole saw and cut a hole in a piece of spare sheet metal and use the new "plug" cut out of the spare sheet metal and weld it in. I did this on my 69 mach 1's shock towers because some jerk used a torch on them at one point in its life. So i just welded a piece of steel behind the hole cut the torched part out and then welded in a new piece cut from a hole saw. Worked great.
Old Oct 10, 2003 | 11:17 PM
ibanez6rg's Avatar
Mine is shaved but the body sshop did it so I don't know what to tell ya!
Old Oct 11, 2003 | 11:55 AM
thanx guys
ttt anyone else have an idea?
Old Oct 11, 2003 | 03:28 PM
AW/whiteZ-28's Avatar
Originally posted by stang_killa94
cut a piece of metal the same shape and size then use a countour gauge to get the exact contour of the body then bend the piece of metal to that shape and then tac weld all the way around til the circle is completed then grind the welds smooth and then do all the body work............at least this is how i remember it being done on trucks tv to cover a key hole
That's exactly how it should be done I'm gonna do the same thing as soon as I buy a welder
Old Oct 13, 2003 | 03:19 PM
CamaroCasanova's Avatar
Sounds about right, I dunno I just had my body shop do it all. Just re-mount the antenna in the trunk somewhere hidden. Usually that is how you shave on metal, so go with it.
www.camarocasanova.freeservers.com
football4life
Oct 4, 2015 07:48 AM
Bxlt1
Sep 10, 2015 08:16 AM
Bxlt1
Jul 18, 2015 02:48 PM
