Sequential turn signals arent working right??
Old Aug 6, 2002 | 05:38 PM
stangspank's Avatar
Post Sequential turn signals arent working right??
car wont signal with headlights on, and inner bulb is much brighter then the others, and when signalling the opposite light lights up also but not as bright, need help if ya can help?
94 Z28(auto)Mods!:
K and N FIPK
Flowmasters Exhaust
Hotchkis Strut Tower Bar
Hidden Shift Kit
Some Strobes
Kenwood CD deck w/ Remote
Massive 600 watt amp
2 12" Cerwin Vegas
Old Aug 7, 2002 | 12:42 AM
Ernster500's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by stangspank:
</font>
That's because you put the bulb in backwards.
Take the assembly back apart. Take the dim bulb(s) out and turn it 180 degrees then plug it back in. Check to make sure they are all working correctly before you reinstall everything.
That should fix it.
I know cause I did the same thing!
E
Ernie's 1994 Camaro Z28 Black, T-Tops, M6: ! CAGS; TB Bypass; ! MAF Scrn; LT4 KM; Pro 5.0; Jamex STB; DMS SFCs; SLP CAI; HPP+; 160 'stat; 3.73s; TA Cover, Jamex Springs; + Fog Lamps; B&M Shifter ****; Chrome Z28 Overlays; Chrome CAMARO Inlay; Black Mast Power Antenna; Sequential Tail Lights, ROH RT 17x9 in Black Ice -w- 275/40-17 RE730s; Air Foil; Hooker Super Comp Cat-back w Hooker Euro Dual Tips; Jet-Hot Hooker Shorty Headers (pending install); Taylor Over-the-Valve-Cover Wires (pending install);
Old Aug 7, 2002 | 07:42 AM
Snoman73's Avatar
Post
where did you get sequential turn signals? do you mean taillights or the front ones?
Old Aug 7, 2002 | 11:01 AM
stangspank's Avatar
Post
aight ill try that thanx
Old Aug 7, 2002 | 11:51 AM
Ernster500's Avatar
Post
aight ill try that thanx</font>
Let us know how it goes...
Old Aug 7, 2002 | 06:42 PM
LS1 RULZ's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Snoman73:
where did you get sequential turn signals? do you mean taillights or the front ones?</font>
Got mine at www.blinkblink.com
They're rear sequential turn signals like they used to have on the old style Cougars.
THE WHITE RASCAL
'99 Arctic White Trans Am w/ Black 30th Anniversary hood stripes
-A4 w/3.23 rear
-Direct Flo lid w/K&N
-raised and sealed lower air box mod
-functional nostril ram air mod
-throttle bump stop mod (4.66v)
-BMR STB
-BMR tubular rubber/poly LCA's
-SLP bolt on SFC's
-Magnaflow cat back exhaust (thanks Wes)
-indexed NGK TR-55's w/Taylor wires
-Firebat decals
-Sequential turn signal mod
-Kenwood KDC-416S HU w/ KDC-C717 10 disc changer, PAC SWI-2, MTX Thunder 4202 main amplifier, MTX Thunder 6500D subwoofer amplifier, Audio Control ESP-2 spatial restorer, Boston Acoustics RC61 6.5" components w/ modified crossovers, JL Audio "Vantage" Stealthbox with an Alpine SWS 1041D Type-S subwoofer @ 2ohms
-Zaino'd regulary
-NFTAC member
-9/11 mod
Sound Domain Install Page
Old Aug 8, 2002 | 10:53 PM
stangspank's Avatar
Post
well the turnin of the bulbs did helkp cuz i noticed they are only made for one way, but i got fed up and put it back to normal so i culd atleast drive around, but problems arose when i was tryin to get it all back to normal...first of all the right turn signal wuldnt work,the flasher clickedoddly, so i figured it was that, but when i changed it it still had the problem and i noticed that without the seauential modules...both tailights still lit up when signalling!!! then i changed the turn signal bulb on the roght side and all was good, so now im back to regular...im gonna try one more time... and ideas or advice...???????
Old Aug 9, 2002 | 12:38 AM
Ernster500's Avatar
Post
well the turnin of the bulbs did helkp cuz i noticed they are only made for one way...</font>
Dang, that sucks man. I noticed that they only went in one way too, but the sockets that came with the kit didn't prevent them from going in the wrong way, so of course, I put them in the wrong way. I think it was two on one and one on the other, but it was a quick fix for me.
You should e-mail Damion and see what he recommends.
Good luck!
E
Old Aug 9, 2002 | 10:15 PM
stangspank's Avatar
Post
well thats who i bought them from, and so far all he has said is to check my connections which i did, and right now im waitin for a reply after i told him that didnt work...so i guess we'll see, and hopefully he knows wuts wrong? well if u guys come up wioth anythin lemme know...thanx for ur help, peace
liamcg97
Nov 25, 2019 05:55 PM
stangspank
Nov 13, 2015 01:02 PM
Injuneer
Dec 15, 2014 09:36 AM
Ryabut98
Sep 3, 2002 11:45 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
