Rubbing with aftermarket hood.
Old May 13, 2006 | 02:34 AM
LT1 POWR's Avatar
Ive got a fiberglass SS hood and my MAF sensor and Moroso CAI rub when the hood is closed. Ive tried repositioning the MAF sensor but it still rubs.
Do any of you guys have this problem and if so what should i do to fix it?
Old May 15, 2006 | 08:33 PM
lt1zpwr's Avatar
Re: Rubbing with aftermarket hood.
ive never really heard of this prob, what brand is your hood? u might want to try adjusting the stops located at the front corners if u trun these it may let the hood sit higher and not rub, good luck
Old May 16, 2006 | 12:47 AM
Brent94Z's Avatar
Super Moderator
I would think if the hood is aligned good you probably don't want to mess with the hood adjustment. I'd check to make sure the cold air is fully seated in that well area. Also check to make sure the radiator/ABS stuff isn't keeping the cold air kit higher than it should be.
What part is rubbing? I'm assuming that it must not be the plug in part because you can rotate that down a bit if needed
Old May 16, 2006 | 03:43 AM
LT1 POWR's Avatar
Yes i rotated the MAF sensor so it wouldnt rub but i think it still is. And i know that my CAI is still rubbing. Im going to mess around with them sometime to try to fix this.
Old May 16, 2006 | 11:19 AM
tfs95z28's Avatar
actually, i have a stock z28 hood and i have recently noticed that the 1LE intake elbow is doing the same thing. The heat shield/foam (whatever it is) on the underside of the hood has indentations from the intake elbow.
I think i might try adjusting my hood to see if it solves it, but this has only started recently and nothing appears to be out of place either.
Kinglouui
May 26, 2016 11:05 AM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
SEOJustin
Sep 24, 2015 04:39 PM
