Rubber Undercoating
Old Feb 18, 2004 | 10:01 PM
30thZ286speed's Avatar
Rubber Undercoating
Has anybody used any of that spray on rubber undercoating in the wheel wells. My rear wheel wells already have some but I am thinking about doing the front and re-doing the rears this spring to try and get rid of the tire noise.
Old Feb 18, 2004 | 10:11 PM
jeff94z28's Avatar
It works. Your talking about the crap they sell in a spray can right? My shop teacher said to heat it up ahead of time to make it spray easier, just run it under warm water a little bit to get the stuff softened up.
Old Feb 18, 2004 | 10:20 PM
Will it help in cutting down the tire noise in the interior?
Old Feb 18, 2004 | 11:50 PM
KillerTA's Avatar
Probably not much and it's pretty messy.
If you're serious about cutting the noise, the dynamat the interior. It's not that hard and if you have a full day, you can probably get a lot done.
Old Feb 19, 2004 | 12:04 AM
lbls1's Avatar
That was one of the first things I did when I picked up my car new. If you live in the rust belt area and drive your car daily or in any weather, this is a must have.
Although the factory has improved anti corrosion protection on american cars, in time continued exposure to salt and harsh weather (coupled with gravel or loose hard debris) will start to chip away at galvanized coatings, and you will end up with some rusting. The undercoat greatly helps shield sheet metal from rust causing elements.
RUENUF
Mar 13, 2016 03:37 PM
95mysticta
Aug 20, 2015 07:43 PM
surreybrad
Jul 29, 2015 02:55 PM
colts0455
Jul 24, 2015 04:51 PM
Jun 5, 2015 10:16 AM
