Replacing White Gauge lights with Blue LED's
Old May 10, 2007 | 12:54 AM
THE_RUCKUS's Avatar
I'm looking to replace the white illuminating bulbs from the gauge cluster, a4 shifter selecter, heater control selector, lighting selector, fog lamp selector, door panel lighting and the defroster selector all with blue LEDs
I'm talking going to this = http://ledgauges.tripod.com/sitebuil...eledgauges.jpg
and this http://ledgauges.tripod.com/sitebuil...camarohvac.jpg
any part numbers / heads up would be AMAZING.
thanks.
Old May 10, 2007 | 07:23 AM
jtblckmaro's Avatar
I did mine with
http://www.superbrightleds.com/mini-wedge.html
194's.
Just gotta pull the stock white bulbs out, pry 'em out of the sockets, then solder these in place. Takes a bit, cuz the solder don't like to stick to the terminals.
Good luck
Old May 10, 2007 | 07:24 AM
jtblckmaro's Avatar
Oh, and the shifter plate and a/c controls, just get the regular led's and associated resistors. Takes a bit of fab on the shifter plate, drill through the white plastic, epoxy the led's in place, then wire 'em up.
The a/c controls, same as the guage face, just pry the bulbs out, solder led's in place.
Have fun
Old May 10, 2007 | 12:24 PM
THE_RUCKUS's Avatar
thats no thing. i work in an install bay and when theres downtime i'll get to it. come to think about it, i have a bunch of viper LED's sitting in my tool box.
do you know the appropriate resistance value of the resistors i should use?
Old May 15, 2007 | 07:36 AM
THE_RUCKUS's Avatar
bump
When wiring the LED's what value resistor is correct?
Jlo
Feb 3, 2015 09:41 PM
ro2207
Dec 4, 2014 06:18 PM
NewsBot
Dec 3, 2014 12:30 PM
30thZ286speed
Aug 3, 2002 04:54 AM
Omega9
Aug 2, 2002 12:33 AM
