Removing VHT
Old May 9, 2010 | 10:04 AM
The Captain's Avatar
Removing VHT
I put VHT on my taillights with a clear overcoat about 3 years ago and I would like to redo it to make it darker. Should I remove the old VHT or just sand over the old stuff and spray it again? If I need to remove it, whats the best method without destroying the lenses in the process?
Old May 9, 2010 | 06:03 PM
Ocala93TA's Avatar
This is just my 2cents but if you wet sand them you should be able to add more vht and then clear , if there peeling go that far and then build up the darkness .
Old May 10, 2010 | 10:54 AM
stroked 383's Avatar
Throttle body cleaner....
or carb cleaner but you gotta get that **** off in light speed! It'll eat thru the plastic
This is how I removed the VHT tint on the maxima after Johnny law told me he couldn't see that I was braking
EDIT: and what Ocala said as well...just wet sand to remove any debris and recoat till you get the darkness you want...save yourself a headache
Old May 10, 2010 | 11:21 AM
Ocala93TA's Avatar
I went a bought a set of lt1 faded ones in case of cops . i just change them out pay the $7.00 fix it ticket then put the shades back on
greenzee28
Sep 25, 2015 04:29 PM
Jake Bialke
Sep 24, 2015 11:31 AM
wbspoon
Sep 19, 2015 08:12 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
