Removing Rear fender on 94 Chevy camaro Z28
Old Feb 17, 2011 | 08:57 PM
lildemars09's Avatar
I have tried to find out how to remove the right passenger rear fender because it was hit and dented in by previous owner. i want to remove it and fix it up but am having a hard time finding out how to easily remove it? i would really appreciate it if anyone could help me out, thank you.
Old Feb 17, 2011 | 11:51 PM
camaro69z's Avatar
Re: Removing Rear fender on 94 Chevy camaro Z28
i dont think thats possible
Old Feb 17, 2011 | 11:57 PM
rsdz302's Avatar
couple cases of bear, then make friends with a good body man.
I have done it on a 69 camaro and it is no picnic. drilling and spot welding and a lot of new language. But in the end it turned out spotless.
Old Feb 18, 2011 | 03:33 AM
L.dookie's Avatar
yeah. you'd have to cut it out, or drill the spot welds out and take it off. i had the same thing happen on the drivers side only i ran into my own car with a semi truck. try looking up something on youtube. i've seen it before. you use a can of duster and a hair dryer or heat gun and it pops right out. i had my friend help me pull the dent out with a stinger. which means grinding down to bear metal and repainting when finished. Good Luck. you could try to find the pictures of mine. https://www.camaroz28.com/forums/sho...d.php?t=777144
Old Feb 18, 2011 | 12:07 PM
Brangeta's Avatar
Keep in mind that the rear quarters are structural and if you cut one out, it may be smart to tack weld a steel brace in so the unibody doesn't deform as a result of cutting it out.
Old Feb 19, 2011 | 09:14 AM
alright thanks a lot, looks like i got a lot of cuss words and sweat coming up for my next project lol
fpete1992
Dec 11, 2014 03:51 PM
ChrisFrez
Dec 7, 2014 06:01 PM
Dec 4, 2014 11:56 AM
NewsBot
Dec 3, 2014 12:30 PM
siguy
Nov 27, 2014 10:07 AM
