removing park lights off lt1
Old Apr 30, 2006 | 07:45 PM
DustinZ28's Avatar
i have a 95 z and was wondering what the easiest way is to remove the corners on it, i am goin to be tinting them and dont kno how to go about taking them off. i know there are 3 bolts holding them on but getting to the bolts is what i need to know.
all help is appreciated
Old Apr 30, 2006 | 07:55 PM
GT KILLER's Avatar
Re: removing park lights off lt1
I know you gotta do it from underneath.....unbolt the plastic underneath the front fascia and you get to the parking light lenses from behind.....I had to replace a bulb on one of mine right after I got the car, and it was kind of a PITA to do because they don't come out from the front. It's been almost a year since I did that so I don't remember exactly how you do it, but I know you have to get under the front of the car and pull the out from the back.
Old Apr 30, 2006 | 08:28 PM
6SpdLT1Z's Avatar
Get under your car and you should see two small things on the sides w/ little vents for the air to go in to the airbox on the DS anyways.
Theres a few bolts, 10M I believe. Take them off.. they're a little bit of a PITA to get out w/o removing the air dam but its not that bad. Once you have those off you will have access to the parking lights, 3 bolts, disconnect the bulbs from the housings.
Old Apr 30, 2006 | 08:33 PM
DustinZ28's Avatar
thanks for the help
Gtpguy
Jan 26, 2015 04:50 PM
4586
Jan 3, 2015 07:22 PM
ro2207
Dec 4, 2014 06:18 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
