removing fog light brackets
Old Feb 13, 2008 | 06:02 PM
Crows89RS's Avatar
i'm installing 1LE fog light deletes, do I pull out the pins on the bottom side of the bumper to get to them and unbolt them or can I do it from the front of the car?
thanks in advance
brett
Old Feb 13, 2008 | 07:41 PM
94_LT1_Z28's Avatar
I could be wrong but I'm pretty sure you have to pull the pins on the bottom, especially if you have fog lights in right now
Old Feb 13, 2008 | 08:26 PM
Crows89RS's Avatar
also, does anyone know if the screws for the 1LE grilles are just some run of the mill self-tapping screws? or are they special for some reason or another? because there are no pre-existing holes in my bumper to mount the grilles...
Old Feb 13, 2008 | 09:49 PM
MarcR94v6's Avatar
Are you talking about the metal pieces? I was unaware those could be removed. I just bent the tabs back slightly so I could put the grills on just the way I wanted them.
Just mount the grill how you want it, mark the holes and use a drill to put it directly in the plastic.
Old Feb 13, 2008 | 10:18 PM
Crows89RS's Avatar
what kind of screws should i use? can I find them at a hardware store? dealer said they wouldn't be able to get them for about a week for one reason or another...
Old Apr 20, 2008 | 07:34 PM
carolinacasper's Avatar
Where did you get the kit from?
Jlo
Feb 3, 2015 09:41 PM
alphaauto
Jan 23, 2015 07:42 AM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
30thZ286speed
Aug 3, 2002 04:54 AM
